How To Remove Purple PVC Cleaner From Vinyl - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2012, 09:30 AM   #1
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
How to Remove Purple PVC Cleaner From Vinyl
After a month our grandson and I finally have our half bath 99% finished. We still have a month or so to just get everything back to abnormal, like replacing the floor and a few joists, mud ceil outside band etc. The fellows who worked on this house before did a really hacked up job.
Well anyway, on to the question, I dropped a drop of purple PVC cleaner on the vinyl floor and we have done everything we can think of to get it up, nothing will touch that stuff. Do any of you have a secret weapon to remove this spot other than replacing the flooring? I hate to rip all of it back up and install again.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-12-2012, 09:35 AM   #2
Rewards Points: 12,792
Mineral spirits on a terry cloth rag using just the tip of your finger to minimize the chance of also removing the finish.
It is some nasty stuff, for DIY jobs I use clear cleaner, for inspected jobs the inspector wants to see that you used cleaner.
Old 08-12-2012, 12:45 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Thanks Joe, I don't know why I didn't think of the clear cleaner, when we get to the main bath remodel I will use the clear. I will give the mineral spirits a try, we have tried fingernail polish remover and alcohol so far but it didn't do any good. Thanks buddy
Jim
Old 08-12-2012, 01:01 PM   #4
DIY staff
Rewards Points: 7,174
I haven't seen clear cleaner in about four years---I sure miss it--that purple stuff seems to spatter for ten feet if you let it.--hate that ---
I know of nothing that wall get the purple off of vinyl flooring---
Old 08-12-2012, 02:34 PM   #5
years ago i knew someone that got a drop of glue on a vinyl floor and tried to use cleaner to get it off and it dissolved the vinyl.
Old 08-12-2012, 05:06 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
That is what I am afraid of Mike, it just may have to stay there and wear off, I sure don't feel like taking every thing back up right now. I am afraid to try too much, like Danny said it may desolve the flooring.
Jim
Old 08-12-2012, 07:15 PM   #7
DIY staff
The color will fade with time
Old 08-12-2012, 08:55 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Thanks Mike that is encouraging.
I ran into a situation I haven't seen before, when I took the electric wall heater out I noticed it had a separate wire as a ground, when I went under the house I found the other end of the ground wire just laying on the ground attached to nothing. How could the wall heat work without a ground wire?
Jim
Old 08-12-2012, 08:59 PM   #9
There is no ground needed to make it work. All it was there for is to not make you the ground and kill you.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
BigJim (08-12-2012), oh'mike (08-12-2012)
Old 08-12-2012, 09:24 PM   #10
DIY staff
The 'used' power returns to the breaker box on the neutral. the ground is there to keep the case safe in case a power wire ever shorts out against the metal cover---
BigJim (08-12-2012)
Old 08-13-2012, 10:07 AM   #11
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Spatter, let alone the fact that as soon as you open the lid to the can, it's wicking up your fingers all the way to your elbow and dripping off.......
I dropped a small spot on some linoleum in a mechanical room when I first started. It was a good lesson, and I haven't done it since. Of course being that it was a mechanical room, nobody cared at all.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
BigJim (08-13-2012), oh'mike (08-13-2012)
Old 08-13-2012, 10:44 AM   #12
DIY staff
And never seals tight when closed--so it spills out onto the tools in the bucket---and stinks up the truck on the way home---
Old 08-13-2012, 04:00 PM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
You hit that nail on the head.
Jim
Old 08-13-2012, 09:58 PM   #14
Doing it myself
Alan's Avatar
At least you feel good by the time you get home. . . .
Journeyman Plumber
Old 08-13-2012, 10:01 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 346
I glued up some 6" sch 80 with purple primer and gray glue recently. I didn't need to wait till I got home.
Completely remove vinyl adhesive before tile? JetSetEng Flooring 2 04-19-2012 06:47 AM
Remove old vinyl floor that's curling at the edges? julzology Flooring 9 03-20-2011 07:07 PM
glueless Vinyl product NoviceDIY Flooring 7 08-20-2010 06:52 AM
Remove vinyl? bob22 Flooring 2 12-02-2009 08:43 PM
