How To Remove Plastic Pipe On Bathtub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-06-2011, 04:12 PM   #1
how to remove plastic pipe on bathtub faucet
My bath tub faucet was leaking and I though it was the pipe since the water was coming through the small space between the faucet and the wall. I took the faucet of to see and there was not a leak coming from the pipe. It was the faucet that was not working right maybe it was just lose, either way when I removed it I could not put it back on because the tip of the pipe pipe was broken off. I went and bought a cheap one from Lowe's till I could get the same one I had. Problem is I can not get the white pipe off. I think the person that put it on used a pipe joint compound. I am not sure if this is why i can not get it off or not. I am looking for any ideas, I do not know much but I pick it up quick. Please help.
beverly78 is offline   Reply With Quote
Old 08-06-2011, 04:17 PM   #2
a picture would help a lot. are you talking about the plastic piece that was inside the tub spout?
Old 08-06-2011, 04:25 PM   #3
yes, sorry I cant put up a pic.
Old 08-06-2011, 08:06 PM   #4
Never mind tin snips did the job.
trying to remove tub faucet cartridge trolleyman Plumbing 1 06-10-2011 06:57 AM
Bathtub faucet leaks from screw hole under faucet. Debmmill Plumbing 3 02-13-2011 06:43 AM
Bathtub spout pipe ~ a watery mess alacea Plumbing 1 11-27-2010 12:22 PM
(Need Advice) Remove 1/2" galvanized NPT pipe from END VillageIdiot Plumbing 5 02-15-2010 06:31 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
