How To Remove Old Valve Stem? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2010, 12:53 PM   #1
Rewards Points: 22
How to remove old valve stem?
I'm helping my brother fix a leaky tub faucet in his 1933 colonial style home. I've handled a bunch of small plumbing projects before, but never dealt with this style valve before. If it's original I may need to use much more caution or call in a plumber. My brother tried taking it off with a pipe wrench but it did not budge. Would a socket wrench be better for this situation? Also, how do you troubleshoot an old valve like this? The handle says Crane, and so does the pipe behind the wall (we have an access panel behind)
Thanks in advance - Rick
Mantaray14 is offline   Reply With Quote
Old 10-31-2010, 01:35 PM   #2
HVAC / Plumbing
That nut should come off the end. As old as that valve is it may break.. Be prepared to replace it
kenmac is offline   Reply With Quote
Old 10-31-2010, 02:17 PM   #3
Rewards Points: 22
Thanks for your input.
Can you recommend the best tool/technique to get the nut off without disturbing the surrounding tile?
Best regards,
Rick
Old 10-31-2010, 05:01 PM   #4
HVAC / Plumbing
I would use a small pipe wrench. I did tell you to be prepared.. Meaning, to install a new unit. It's possible it will break ( it's old)
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 11:02 AM
broken ball valve stem Doc O'Connor Plumbing 6 09-11-2010 09:08 AM
Shower valve stem extension? markd5469 Plumbing 1 07-05-2010 06:48 PM
Double Check Valve installation (and a few other questions) secutanudu Plumbing 0 04-17-2009 07:42 AM
