How To Remove Grout/thin Set Around Bathtub Stems - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-01-2009, 07:12 PM   #1
Question
How to remove grout/thin set around bathtub stems
I live in an older house with a leaky bathtub which drips from the showerhead and/or sprout. The interior of the bathtub/shower walls are 6” x 6” tile. I attempted to replace all three stems which would stop the leak. But the problem is that when I removed the knobs to expose all three stems two of them (hot & cold stems) are covered with either grout or thin set. So I started chipping it away to expose the two stems but this process is long and time consuming. This should have been an easy job but it’s impossible to remove and replace the stems if I cannot clear away the grout/thin set around the nut of the stems.
Is there a tool or liquid solution I could purchase to remove the grout/thin set more easily without damaging the tile?
Thanks, Ralph
augits is offline   Reply With Quote
Old 10-02-2009, 06:01 AM   #2
Remodeling Contractor
use Simply Green cleaner. It will dissolve the grout, thinset or cement
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Remove tiles around sunken bathtub Sabine Tiling, ceramics, marble 3 12-15-2008 06:29 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help! I can't remove a bathtub drain after I broke the crossbars with a wrench andreajohanson Plumbing 18 04-24-2008 11:47 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
