Old 03-26-2011, 05:33 AM   #1
how to remove a fibreglass repair
Hi Guys
The u-bend on this sink needs replacing, but it has been repaired with a fibreglass repair. I need to be able to take this off, if its possible, to change the u-bend. Has anyone got any suggestions how to do this. Is there a solvent that I can use to loosen it, or something?
I have attached a foto for you to see the problem.
Thanks for your time in reading
Kwisj
kwisj is offline   Reply With Quote
Old 03-26-2011, 06:23 AM   #2
Super Moderator
Cut it and split the fiberglass----the sink may be ruined.---Sorry---Mike---
oh'mike is online now   Reply With Quote
Old 03-26-2011, 12:30 PM   #3
sawsall, hammer and chisel
plumberinlaw is offline   Reply With Quote
Old 03-26-2011, 01:36 PM   #4
maybe a dremel with a small cutoff wheel. go slow and pry it off as you cut it
the_man is offline   Reply With Quote
Old 03-26-2011, 03:05 PM   #5
Homerepairguy's Avatar
Acetone is the solvent used to thin fiberglass resin. But it will not melt the mass of fiberglass that is shown in your picture. Note that Acetone is highly flammable so proper precaution must be taken if using it.
The dremel idea is a good one. An oscillating multi-tool might be good also to cut away the mess while still allowing control of the cutting. You will probably still have to chip away remaining fiberglass. Be sure to wear goggles and a mask that can filter the fine cutting dust and wear a long sleeve shirt that you can throw away. Fiberglass dust getting into skin pores can drive one mad for a couple of days depending on the person's sensitivity. Rubbing exposed skin with baby powder before starting can minimize fiberglass dust from getting into skin pores.
HRG
Homerepairguy is offline   Reply With Quote
Old 03-26-2011, 03:18 PM   #6
nap
You talking to me?
nap's Avatar
one has to wonder why that was done to begin with. If the sink is already damaged, it might have simply been a means to an end without replacing the sink. I would head into this project with knowing there is a great possibility the sink needs to be replaced and be prepared for it.
Old 03-26-2011, 03:24 PM   #7
Yep, what he said.
HRG
Old 03-26-2011, 05:35 PM   #8
Hi guys thanks for all the advice. Will probably get hold of something to cut it with...I may try the acetone as well, as I just happen to have some! Good call about the fibreglass dust, I would not have thought about that, and I would have been itching for days.
Cheers again to you all.
Kwisj
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 11:45 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
How to gently remove (aluminum) soffit? superfly Roofing 1 09-06-2009 10:15 PM
What do you guys think of this roof repair job? darsunt Roofing 7 08-21-2009 09:43 PM
