How To Remove Faucet Hole On A Quartz Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2012, 12:12 AM   #1
747
registered
747's Avatar
Rewards Points: 534
How to Remove Faucet Hole on a quartz Sink
I bought new vanity top for 2nd bathroom. Its quartz with under mount sink. Two holes are good to go. But the one in the middle has sticker over it saying tap here. On reverse side there is sticker saying tap out on other side. How would you recomend me taping this out. I was thinking maybe a small metal punch tool. Which i do have different size ones. I was thinking small then medium. It only has to be big enough for up and down drain lever. I don't understand why the drilled the other two completely but not the middle. I definately want to handle with care.
747 is offline   Reply With Quote
Old 09-27-2012, 12:52 AM   #2
Rewards Points: 558
Is there a plug that they want you to remove? Or are they saying that your “tap” goes there? Can you provide a picture to clarify?
epson is offline   Reply With Quote
Old 09-27-2012, 01:38 AM   #3
DIY staff
Rewards Points: 7,174
Sounds like they have drilled it almost all the way through--so a gentle tap with a small hammer should knock it right out----Place a scrap of wood on top of the plug--tap on that---
Old 09-27-2012, 02:23 AM   #4
747
registered
747's Avatar
Rewards Points: 534
Originally Posted by oh'mike View Post
Sounds like they have drilled it almost all the way through-----
Exactly you can see this from the bottom. I was going to use a 1/4 inch punch put it in middle lightly tap it with a hammer. Other two holes are drilled through.
Old 09-27-2012, 02:48 AM   #5
DIY staff
You will be fine-----they pop out with one sharp tap
New sink in Cottage getting WORSE and WORSE - need filterless faucet? LordX Plumbing 6 06-16-2012 09:19 PM
Delta kitchen faucet is leaking under the sink grave20 Plumbing 2 04-01-2012 02:00 PM
Under sink filtration install problem? Water comes out faucet side when disposal on sprtfan Plumbing 16 08-17-2010 11:13 PM
Sink holes are larger than o'ring on faucet jaymalea Plumbing 2 03-24-2009 09:52 AM
Sink hole too big for drain. DIYRookie Plumbing 1 10-03-2008 05:53 PM
