How To Remove Faucet Handle - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2011, 04:59 PM   #1
Rewards Points: 192
How to remove faucet handle
Hi!
How do you go about removing the handle on the faucet in this picture?
Uploaded with ImageShack.us
One would think the little caps on the handles would pop off, but they didn't. I just used my fingernail and it's like they couldn't lift off. I didn't want to try a screwdriver before checking here to see if anybody has any hints.
Thanks!
wiz561 is offline   Reply With Quote
Old 06-15-2011, 05:21 PM   #2
Rewards Points: 1,646
Go to:
http://www.moen.com/consumer-support...al?id=moen0132
see step 4a.
bob22 is offline   Reply With Quote
Old 06-15-2011, 05:31 PM   #3
looks like a small cap on the top that you pry out to access the screw or it has a set screw in the back side or its the kind where you hold the lever and unscrew the bottom from the faucet
Old 06-15-2011, 05:32 PM   #4
Danny, go to the link.
Old 06-15-2011, 06:21 PM   #5
Rewards Points: 192
Thank you for the responses.
I saw that web site and tried 4a, but it didn't work. The only part that rotates is the handle part. The area below the handle doesn't rotate.
I would think it would be a cap on the handle, but I didn't want to gouge or scratch the handle if it won't work.
I'm open to other ideas!!
Thanks!
Old 06-15-2011, 06:30 PM   #6
You may need to apply a bit of force to get the lower part to move; it may be stuck with corrosion, deposits, etc...Try one of those rubber jar openers or something that won't scratch the lower part (rotate ccw).
Old 06-15-2011, 08:38 PM   #7
i checked the link after i posted the last one. they had just come out with that handle style just before i got out of plumbing. got tired of it after 20 years. like bob said it might be kinda tight fro, corrosion
Old 06-16-2011, 04:38 PM   #8
Rewards Points: 192
Thank you all for the responses.
When I got home today, I used a rubber strap wrench and was able to rotate the area right under the handle in order to remove it, just like everybody mentioned. I didn't scratch anything and it worked out great.
Thanks for the help!!
Old 06-16-2011, 04:57 PM   #9
Congrats! Strap wrench use is rarely needed but when it is, nothing beats them.
Faucet Handle Has Stripped Teeth sweaty Plumbing 1 04-30-2011 09:06 PM
Broken Shower Faucet Handle DFT Plumbing 1 02-23-2011 08:55 AM
problem: remove bath faucet rjw_mpwr Plumbing 2 06-05-2010 02:55 AM
Concinnity Single Handle Kitchen Faucet longeye Plumbing 0 02-05-2010 01:58 PM
Faucet handle faces the wrong direction. diyntn Plumbing 1 04-22-2009 08:09 PM
