How To Remove Compression Ferrules From Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2013, 09:57 AM   #1
jkk
Rewards Points: 233
How to remove compression ferrules from copper pipe
In order to replace drywall behind sink, I'll need to get the nuts and ferrules off the 1/2" copper pipe. How do you get these compression ferrules off?
jkk is offline   Reply With Quote
Old 01-28-2013, 10:21 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Grab the nut with pliers and wriggle it as you pull. If the ferrule is not embedded too deep- should work.
Or you go out and buy a ferrule puller
Old 01-28-2013, 10:41 AM   #3
Rewards Points: 12,808
I've never been able to get one off and still have a useable surface.
I just cut it off behind the farrel with my ossilating saw and clean it up with a file.
COLDIRON (01-31-2013)
Old 01-30-2013, 11:32 AM   #4
Joecaption has got it right.
Once the ferrule is tightened if it is done correctly it will become part of the tube or pipe that it is secured to. Even if you were to somehow cut the ferrule off you would find that the tube where it was is deformed and will not accept another ferrule without leaking.
Kapriel is offline   Reply With Quote
The Following User Says Thank You to Kapriel For This Useful Post:
Old 01-30-2013, 11:48 AM   #5
DIY staff
Rewards Points: 7,174
You are going to hide the hole with an escutcheon---so leave the nut and use a split plastic escutcheon.
I don't like spelling escutcheon---so I'll leave now --I can spell and the spell check wants things close or it won't correct me----
BigJim (01-30-2013)
Old 01-30-2013, 11:57 AM   #6
Roofmaster
Rewards Points: 2,172
Cut the pipe 3 inches away and add a coupling.
The Following User Says Thank You to jagans For This Useful Post:
Old 01-30-2013, 12:36 PM   #7
jkk
Rewards Points: 233
Are the "press-on" fittings reliable?
Old 01-30-2013, 12:42 PM   #8
sharkbite are good
paintdrying is offline   Reply With Quote
Old 01-30-2013, 04:36 PM   #9
jkk
Rewards Points: 233
Lowes does not carry those, they carry another brand. I'm thinking about using them to cap a water hammer arrestor that I'm shortening- they work on air filled pipes, right?
Old 01-30-2013, 06:29 PM   #10
Rewards Points: 1,214
You have to cut it off.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 01-30-2013, 06:30 PM   #11
jkk
Rewards Points: 233
Cut what off?
Old 01-30-2013, 06:35 PM   #12
Plumber
Rewards Points: 348
Is this the ped sink? If the drywall is cut below the tee- why not unsweat the tee and replace it with a 90 and new stub out? Now you don't have to worry about the nuts or lowering the chamber. Plus, you could move the stubs closer together and be hidden behind the pedestal?
Old 01-30-2013, 06:51 PM   #13
Where do you buy a ferrule pulled at?
You a plumber?
Never seen someone pull one off. If it was install right the only way is to cut it off.
handyman21 is offline   Reply With Quote
The Following User Says Thank You to handyman21 For This Useful Post:
Old 01-30-2013, 06:59 PM   #14
Plumber
Rewards Points: 348
You a plumber?
http://www.lowes.com/pd_332073-943-3...ductId=3329486
Plumbing since the mid 80's- learned to crawl on an 18 story motel project.
I have used pullers several times- almost always been able to reuse the stub out.
First time I bought the tool was about 10 years ago- remodeled a Motel 6 and had only a handful of stops that we couldn't get off with pliers and they were too close to cut.
Old 01-30-2013, 06:59 PM   #15
DIY staff
Yes, he's a plumber---and Yes there is a puller designed to remove the ferrule --and Yes--the pipe is often dimpled by the old ferrule--making that unusable for installing a new one in the same spot
Welcome to the site!
Is this an easy copper pipe repair? Telfair Plumbing 16 03-25-2012 06:55 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
how to remove plastic pipe on bathtub faucet beverly78 Plumbing 3 08-06-2011 09:06 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 06:02 PM
