How To Remove Broken Piece From Showerhead Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-26-2011, 10:36 AM   #1
How to Remove Broken Piece from Showerhead Pipe
As seen in this picture, the showerhead pipe has been completely cleaved. A piece of the showerhead pipe is still inside the waterline pipe, and the piece is still stuck to the waterline pipe.
What is the best way to remove the showerhead piece from the waterline pipe?
Thanks!
Cindy_Home is offline   Reply With Quote
Old 12-26-2011, 11:07 AM   #2
MarginallyQualified
Rewards Points: 2,464
best? simplest? least likely to create five other problems?
with the right tools and patience you *might* be able to work the thread loose... or not.
I'd look to cut the riser pipe an inch or so below the elbow
(leave enough room for a coupling to be sweated into place)
then replace the elbow fitting altogether.
hth
Old 12-26-2011, 01:11 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,352
Ayuh,... They make Easy-Outs that'll fit, 'n with abit of heat, oughta work...
Bondo is online now   Reply With Quote
Old 12-26-2011, 01:12 PM   #4
i had to remove a few of these in my 20 years as a plumber. I would take a hacksaw blade and cut a slit front to back. cut til you just get through to the threads no more then take a small screwdriver and peel out the broken part. make sure not to booger the threads in the elbow. use teflon tape on the new shower arm and you should be ok. remember just cut through the wall of the broken piece and not into the threads of the drop ear ell in the wall.
The Following 2 Users Say Thank You to DannyT For This Useful Post:
plummen (12-26-2011), VIPlumber (12-26-2011)
Old 12-26-2011, 01:27 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Use the "extracting tool" they make for that exact purpose and you won't have to cut anything and screw up something else in the process. It will take about forty seconds to remove it.
XXX
Old 12-26-2011, 02:16 PM   #6
Rewards Points: 13,694
http://www.plumbersurplus.com/Prod/P...230021/Cat/655
You can buy on at Lowes or Home Depot in the plumbing tool area.
Old 12-26-2011, 03:00 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Some times that works easily,some times it doesnt
plummen is offline   Reply With Quote
Old 12-26-2011, 03:02 PM   #8
Thank you all for your replies and suggestions. We'll try getting it out.
Old 12-26-2011, 05:13 PM   #9
That drop leg was installed wrong any way and should be fixed.
Anyone else notice there's no screws in the ears?
Not sure why you opened up that great big hole for such a simple fix. now your stuck with a repair.
Old 12-26-2011, 05:59 PM   #10
plummen's Avatar
"Doesn't" for who. Never had a problem with the tool or the process.
Cant tell from the picture what the nipple is made of,depends on material and how long its been in there.
Old 12-26-2011, 06:30 PM   #11
plummen's Avatar
I know what the tool is,ive probably got one propping up the corner of the bench in my shop for all those cheasey things are worth to me!
I couldnt tell from her picture what material the nipple was made of,But id be willing to bet I could get it out easy enough with a small chisel and hammer in less than a minute if need be by folding the nipple into itself without hurting any threads
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (12-26-2011)
Old 12-26-2011, 07:06 PM   #12
plummen's Avatar
I really do hope the homeowner doesnt just shove one of those extractors in there and just start yanking with a 24" pipewrench.
It may just turn right out ,or it might end up twisting that 90 and the nipple above it off also.
If youre going to use one of those tools from the bob villa tool line do yourself a favor and heat the fitting up around the nipple first,when things break off like that theres normally a reason for it
Old 12-27-2011, 02:42 PM   #13
The hole was already there from the former homeowner.
May I ask what is wrong with the drop leg? How should it be installed?
Thanks!
Old 12-27-2011, 03:30 PM   #14
plummen's Avatar
it should be screwed to a stud/framing in the wall
Old 12-27-2011, 03:36 PM   #15
There should be a 2 X 4 laying flat between the suds set to a depth just behind the drywall and it gets screwed to that. That's why there's two holes in it. The way it sits now it can more in and out.
plummen (12-27-2011)
Need to Remove Gas Flue Pipe FixingProblems HVAC 2 04-08-2009 08:41 PM
Broken Drain Pipe - Outside of House - Explative Explative Explative - Leah Frances Plumbing 17 05-09-2008 12:47 AM
Broken pvc pipe Keyo77 Plumbing 21 10-20-2007 03:57 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
How do I remove a piece of broken PVC? Geoffro Plumbing 3 04-21-2007 08:59 AM
