How To Remove Bathtub Stopper - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2010, 01:47 PM   #1
How to remove bathtub stopper
I searched and didn't find anything helpful. I have a bathtub stopper that you push down to close it to hold water and you push down on it again to open and drain the water.
I can unscrew the stopper's metal cap from the stopper's plastic doohickey in the drain, but how in blue blazes do you remove the plastic doohickey in the drain? It's stuck and I didn't see any screws or anything.
Brak is offline   Reply With Quote
Old 08-05-2010, 02:13 PM   #2
Handyman
Rewards Points: 512
You need to unscrew it with a drain wrench (see pic). Why are you taking it out though? You can purchase the pop-up seperately.
canadaclub is offline   Reply With Quote
Old 08-05-2010, 11:02 PM   #3
Rewards Points: 352
Use channel locks, if it's stuck force it if it breaks it needed fixing anyway
plumberinlaw is offline   Reply With Quote
jammed Brass overflow stopper Raouf Plumbing 1 11-14-2009 06:11 AM
How to remove grout/thin set around bathtub stems augits Plumbing 1 10-02-2009 06:01 AM
Remove tiles around sunken bathtub Sabine Tiling, ceramics, marble 3 12-15-2008 06:29 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help! I can't remove a bathtub drain after I broke the crossbars with a wrench andreajohanson Plumbing 18 04-24-2008 11:47 PM
