How To Remove Bathtub Overflow Plate - No Screws - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2013, 11:48 AM   #16
Rewards Points: 368
Originally Posted by noclothes View Post
How do I remove this one? Around the entire perimeter of the cover, there are no setscrews, it's just nice clean chrome. It turns slightly in either direction to open and close the drain stopper, through a linkage. I'm a little scared to try to pry it off, or to just "turn really hard" in one direction or the other...there must be a trick. There's no brand name on the cover, though other components in the tub are from Drake and Grohe.
Or should I even be trying to take it off? It's impossible to snake the tub through the drain, because there's a plastic nonremovable baffle just under the drain cover.
The drain is probably plugged with hair and bleach dissolves hair. So rather than attempting to remove parts that some designer had to make look beautiful rather than functional just put a cup of bleach in the drain and let set for about 20 minutes and then add a gallon of hot water. Repeat if the drain remains partially plugged.
Old 03-04-2013, 06:21 PM   #17
Rewards Points: 1,294
Originally Posted by royalsmith View Post
There is good idea of replacement of bathtub overflow plate.Basically replacement of overflow plate is easy job but another problem is no screws.could you give me hint of bath tube drain stoppers?
Aaaaand .....the winner......of the most incomprehensible post of the week is........
danpik is offline   Reply With Quote
Old 08-05-2016, 11:56 PM   #18
Rewards Points: 2
Re: how to remove bathtub overflow plate - no screws
Plumingfix--
I found your post about trying to remove an old tub overflow plate/cover with an image search. I have the same one and need to remove it to resurface the tub. Did you ever figure out how to get it out?
Thank you for any assistance you can offer.
JLPDIY is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
bathtub overflow and drain not lining up megan911 Plumbing 0 04-05-2011 08:00 PM
bathtub overflow drain not lining up plumbernewbie Plumbing 6 09-18-2010 06:34 PM
Help! I can't remove a bathtub drain after I broke the crossbars with a wrench andreajohanson Plumbing 18 04-25-2008 12:47 AM
Hair in tub drain danceken Plumbing 5 05-24-2007 09:53 PM
