How To Remove Bathtub Overflow Plate - No Screws - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2012, 08:01 PM   #1
how to remove bathtub overflow plate - no screws
Almost all the bathtub overflow plates I can find on the web show one (or two) long screws attaching them to the overflow pipe. I am trying to remove an overflow plate that does not have these screws. I'm guessing that the overflow plate itself screws onto the pipe, and I've tried turning the entire plate, but no luck. Are there standard ways these things are attached? Thanks.
plumbingfix is offline   Reply With Quote
Old 04-10-2012, 08:05 PM   #2
Rewards Points: 14,020
I've never seen or heard of one with no exposed screws.
Any access from the back side?
Got a picture of it?
Old 04-10-2012, 08:05 PM   #3
Rewards Points: 582
a picture is worth a 1000 words....
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (04-10-2012)
Old 04-10-2012, 08:26 PM   #4
here it is...thanks...
Old 04-10-2012, 08:28 PM   #5
Rewards Points: 582
looks like the little knob that holds chain unscrews....to remove face plate nice picture by the way....
The Following 3 Users Say Thank You to ben's plumbing For This Useful Post:
COLDIRON (03-04-2013), Ghostmaker (08-06-2016), oh'mike (03-03-2013)
Old 04-10-2012, 08:29 PM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Maybe the pin in the middle holding the chain serves as the screw?
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
ben's plumbing (04-10-2012)
Old 04-10-2012, 08:47 PM   #7
No luck. The pin/knob in the center is attached solid with the plate. I tried turning the whole thing from the pin (which would be the same as turning the whole plate from its outer edge, but perhaps with better leverage), but it doesn't budge.
Old 04-10-2012, 09:16 PM   #8
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
It does un screw. Put a screwdriver in there or pliers to hold the plate whole trying to turn it.
Spray some type of lubricate on there.
The Following 6 Users Say Thank You to sublime2 For This Useful Post:
ben's plumbing (04-11-2012), COLDIRON (03-04-2013), Ghostmaker (08-06-2016), hammerlane (03-03-2013), Javiles (03-03-2013), jaydevries (04-10-2012)
Old 03-03-2013, 12:43 PM   #9
Here's another, but REALLY no screws
How do I remove this one? Around the entire perimeter of the cover, there are no setscrews, it's just nice clean chrome. It turns slightly in either direction to open and close the drain stopper, through a linkage. I'm a little scared to try to pry it off, or to just "turn really hard" in one direction or the other...there must be a trick. There's no brand name on the cover, though other components in the tub are from Drake and Grohe.
Or should I even be trying to take it off? It's impossible to snake the tub through the drain, because there's a plastic nonremovable baffle just under the drain cover.
noclothes is offline   Reply With Quote
Old 03-03-2013, 01:26 PM   #10
Rewards Points: 42
You should have started a new thread so it's easier for others to understand the real issue.
Is there a slot on the underside of the handle for water to pass through? There's probably a set screw hidden in there.
djlandkpl is offline   Reply With Quote
Old 03-03-2013, 01:44 PM   #11
Thanks...there's no slot, I think water would just seep out around the cover; in any event, I can't find a slot, or a setscrew. But you think there must be one?
Old 03-03-2013, 01:46 PM   #12
Plumber
TheEplumber's Avatar
Rewards Points: 820
I believe it either unscrews or pops off
Old 03-03-2013, 02:26 PM   #13
Roofmaster
Rewards Points: 2,210
Use a mirror under the cover. If it turns it has to have a set screw that bears on a flat spot on a shaft, otherwise it would not operate. I suppose the cap might pop off too and hide a splined shaft. If this is the case, You should see a little area where the black plate has a slot in it. Again, look with strong lighting and a mirror.
Old 03-04-2013, 09:38 AM   #14
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by royalsmith View Post
There is good idea of replacement of bathtub overflow plate.Basically replacement of overflow plate is easy job but another problem is no screws.could you give me hint of bath tube drain stoppers?
YES!
Journeyman Plumber
Old 03-04-2013, 09:53 AM   #15
Roofmaster
HUH? Is this in code? Wait, let me grab my Enigma machine.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
bathtub overflow and drain not lining up megan911 Plumbing 0 04-05-2011 07:00 PM
bathtub overflow drain not lining up plumbernewbie Plumbing 6 09-18-2010 05:34 PM
Help! I can't remove a bathtub drain after I broke the crossbars with a wrench andreajohanson Plumbing 18 04-24-2008 11:47 PM
Hair in tub drain danceken Plumbing 5 05-24-2007 08:53 PM
