How To Remove This Antisiphon Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2013, 12:40 PM   #1
Rewards Points: 29
How to remove this antisiphon valve?
Is there a way to remove this? The valve is completely broke and no water actually makes it into the hose. It looks like the whole thing might unscrew, but I don't know and don't want to force it.
Thx
sparky472 is offline   Reply With Quote
Old 05-11-2013, 12:47 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
Not to insult you, but you did try pliers, right? And yes it does unscrew.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 05-11-2013, 01:40 PM   #3
Rewards Points: 29
I did but it's pretty tight and the pipe itself has a lot of give, so as I said, I'm hesitant to force it and risk damaging the pipe inside the wall. Need some way to loosen the threads
Old 05-11-2013, 02:08 PM   #4
Rewards Points: 13,748
Some have a scew on the side of them that has to be loosened.
Sure your turning it the right way, it's upside down so it needs to be turned counter clockwise.
Old 05-11-2013, 02:24 PM   #5
joed's Avatar
Rewards Points: 12,918
I think you are correct. If you look closely there appears to be a set screw right above the G of GASH.
Old 05-11-2013, 03:42 PM   #6
Rewards Points: 582
you could use 2- wrenches one to hold the male adapter comming out of house the other to remove whole faucet and replace....turn off water 1 st ben sr
Old 05-11-2013, 03:44 PM   #7
Rewards Points: 29
Set screw isn't going anywhere. It's broken off and rusted through what little bit is protruding. I think I can remove the entire valve - if I can loosen up the threads.
Old 05-11-2013, 03:55 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 682
Replace the valve or drill out the tamer resistant set screw- the screw head is designed to snap off when installing the aftermarket VB.
The Following User Says Thank You to TheEplumber For This Useful Post:
Alan (05-11-2013)
Old 05-11-2013, 04:12 PM   #9
Rewards Points: 1,956
uSE A BACK UP WRENCH ON THE COPPER PART AND UNSCREW IT.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Javiles (05-12-2013)
Old 05-11-2013, 04:40 PM   #10
Rewards Points: 29
Tried unscrewing the entires hose valve. But when I do, instead of unscrewing, the pipe coming out of the wall with the male threads turns with it. Tomorrow I'll try spraying some liquid wrench at the junction of the valve and the threaded pipe coming out of the wall and see if that'll loosen the threads up enough. Other ideas welcome. But if I break off a pipe in the wall trying to get the hose valve off, this becomes a much more serious and costly problem.
If liquid wrench doesn't get it l either deal without using that faucet or call a plumber.
As far as drilling out the set screw - any special bit required?
Old 05-11-2013, 05:38 PM   #11
Plumber
Rewards Points: 682
Did you read post #6 & #9? You have to use a back up wrench
Oh, and you did turn off the water main right?
ben's plumbing (05-11-2013)
Old 05-11-2013, 06:31 PM   #12
Rewards Points: 29
What kind of wrench is best to use in this situation? Isn't much to hold on to but threads
Old 05-11-2013, 07:03 PM   #13
Plumber
Rewards Points: 682
In your situation, I'd use a pair of high quality adjustable pliers ( channel locks) on the copper and an adjustable wrench on the bib- or pliers on both.
Pliers are directional like pipe wrenches so use them in the right direction- the jaws will bite into the fitting better.
When reassembling, use an adjustable wrench on the bib so you scratch the finish
Old 05-11-2013, 07:07 PM   #14
Rewards Points: 29
Awesome. Thx. I'll give it a shop tomorrow.
Old 05-11-2013, 07:11 PM   #15
Plumber
Rewards Points: 682
What ever you do, don't let the copper line turn.
If you do, you may actually be corkscrewing (kinking) the pipe inside the wall- not good.
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Main Water Shutoff Valve problem obadran Plumbing 16 12-10-2012 11:45 AM
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 07:50 AM
Remove saddle valve for ice maker line? redge03 Plumbing 3 11-17-2011 11:35 AM
