-   -   How to remove this antisiphon valve? (http://www.diychatroom.com/f7/how-remove-antisiphon-valve-179300/)
sparky472 05-11-2013 12:40 PM
1 Attachment(s)
Is there a way to remove this? The valve is completely broke and no water actually makes it into the hose. It looks like the whole thing might unscrew, but I don't know and don't want to force it.
Attachment 70682
Thx
Clutchcargo 05-11-2013 12:47 PM
63 Attachment(s)
Not to insult you, but you did try pliers, right? And yes it does unscrew.
sparky472 05-11-2013 01:40 PM
I did but it's pretty tight and the pipe itself has a lot of give, so as I said, I'm hesitant to force it and risk damaging the pipe inside the wall. Need some way to loosen the threads
joecaption 05-11-2013 02:08 PM
Some have a scew on the side of them that has to be loosened.
Sure your turning it the right way, it's upside down so it needs to be turned counter clockwise.
joed 05-11-2013 02:24 PM
I think you are correct. If you look closely there appears to be a set screw right above the G of GASH.
ben's plumbing 05-11-2013 03:42 PM
you could use 2- wrenches one to hold the male adapter comming out of house the other to remove whole faucet and replace....turn off water 1 st:thumbsup: ben sr
sparky472 05-11-2013 03:44 PM
Set screw isn't going anywhere. It's broken off and rusted through what little bit is protruding. I think I can remove the entire valve - if I can loosen up the threads.
TheEplumber 05-11-2013 03:55 PM
199 Attachment(s)
Replace the valve or drill out the tamer resistant set screw- the screw head is designed to snap off when installing the aftermarket VB.
Ghostmaker 05-11-2013 04:12 PM
uSE A BACK UP WRENCH ON THE COPPER PART AND UNSCREW IT.
sparky472 05-11-2013 04:40 PM
Tried unscrewing the entires hose valve. But when I do, instead of unscrewing, the pipe coming out of the wall with the male threads turns with it. Tomorrow I'll try spraying some liquid wrench at the junction of the valve and the threaded pipe coming out of the wall and see if that'll loosen the threads up enough. Other ideas welcome. But if I break off a pipe in the wall trying to get the hose valve off, this becomes a much more serious and costly problem.
If liquid wrench doesn't get it l either deal without using that faucet or call a plumber.
As far as drilling out the set screw - any special bit required?
TheEplumber 05-11-2013 05:38 PM
199 Attachment(s)
Did you read post #6 & #9? You have to use a back up wrench
Oh, and you did turn off the water main right?
sparky472 05-11-2013 06:31 PM
What kind of wrench is best to use in this situation? Isn't much to hold on to but threads
TheEplumber 05-11-2013 07:03 PM
199 Attachment(s)
In your situation, I'd use a pair of high quality adjustable pliers ( channel locks) on the copper and an adjustable wrench on the bib- or pliers on both.
Pliers are directional like pipe wrenches so use them in the right direction- the jaws will bite into the fitting better.
When reassembling, use an adjustable wrench on the bib so you scratch the finish
sparky472 05-11-2013 07:07 PM
Awesome. Thx. I'll give it a shop tomorrow.
TheEplumber 05-11-2013 07:11 PM
199 Attachment(s)
What ever you do, don't let the copper line turn.
If you do, you may actually be corkscrewing (kinking) the pipe inside the wall- not good.
