How To Remove A 20 Year Old Delta Shower Handle - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-26-2011, 04:32 PM   #1
how to remove a 20 year old delta shower handle
I'm trying to replace my 20 plus year old delta shower single level faucet. I've removed the lever handle, and unscrewed the backplate. I'm uncertain how to remove the the center portion that will give me acess to rough plumbling. Unless it is on bottom, I see no evidence of a hex screw to remove. I've tried to slide it off and used my large plyiers to try and unscrew it. I did not want to break it, so I left it alone. Is this enough information for anyone to provide any suggestions on my next step.
mcvrlje is offline   Reply With Quote
Old 06-27-2011, 06:27 AM   #2
Backplate??? Most Delta's have a large finished(chrome/brass/etc.) nut under the handle. With this removed, you have access to the ball and rubber cone washers.
Old 06-27-2011, 07:10 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
The dome cap under the handle is unscrewed by turning it counter-clockwise. Grip the threaded base of the cap with a pair of channel-lock pliers or a small pipe wrench. Once you break it loose, it should be easy to unscrew. Usually the threads just get corroded and need a little persuasion.
With the dome cap off, the ball and rubber seats-and-springs will come out. I use a small screwdriver or icepick to get the seats-and-springs out.
I recommend replacing all parts with a genuine Delta repair parts kit.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
help with how to remove shower drain jcon3678 Plumbing 1 12-13-2010 08:15 PM
Trouble replacing 2 handle shower levers matt7125 Kitchen & Bath Remodeling 2 12-02-2009 07:55 AM
Delta 1400 shower wont turn off asherwood1 Plumbing 5 11-05-2009 10:11 PM
Problems replacing two handle shower faucets bear creek Plumbing 3 02-04-2009 06:41 AM
Help Repairing a 25 Year Old Delta Shower Faucet shapeshifter Plumbing 5 07-07-2008 08:24 PM
