How To Put Wax On 3" Inside Fit Toilet Boot? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-06-2007, 12:15 PM   #1
How to put wax on 3" inside fit toilet boot?
After more investigation, I found out I cannot use outside fit toilet flange for the basement bathroom, because the pipe is from concrete and there is not enough room unless I break the concrete which I don't want to do, especially I already lay tiles...
the other option I can see is to use inside fit flange, the problem with this guy is it is so shadow and the hole is smaller to put in the regular wax ring with funnel on top , if I put the wax alone without funnel on it, it is ok, but I can imagine there is a gap between the toilet opening and the flange's hole where there is no funnel guiding the waste, the waste is kind of free falling into the hole, hopefully ... although this gap is really small, like half an inch....etc. but is this a good idea? or how to use the inside fit boot with wax ring?
Thanks for answering.
KUIPORNG is offline   Reply With Quote
Old 03-06-2007, 06:55 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
What your wanting to use is not code approved here, so in my neck of the woods get a chipper out and do it right.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-08-2007, 08:13 AM   #3
Thanks Ron
I did it according you said... and used the regular flange... after chipping out the concrete with hammer drills....
I also got the same feeling as you worrying things won't work... and did it the proper way...
It's all done now...
I wonder why those not code compliance item allow to be sold,...
Old 03-08-2007, 08:15 AM   #4
Journeyman Plumber
There is lots of things sold that are not allowed by code, it's a way of life, this is why we go to school for 4 years.
I'm glad you fixed it right.
Old 03-08-2007, 12:53 PM   #5
Torque, push type or expansion style.
http://www.plumbingsupply.com/toiletflanges.html
redline is offline   Reply With Quote
Old 03-08-2007, 12:58 PM   #6
there are so many variations.... one contractor told me before... better goes with the traditional stuff .... most of the time... rather than new invention...
for this zero tolerence installation... I pick the most common type 4x3 flange and installed it...
thanks anyway...
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 01:22 PM
Toilet running inside bowl leroyme Plumbing 4 08-21-2007 07:50 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 08:34 AM
