How To Put Thin Set Under A Fiberglas Shower Base - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2010, 12:28 AM   #1
how to put thin set under a Fiberglas shower base
I'm a newby to using thin set I have been told it's simple but I need some directions or step by step walk through to ensure that the job is done correctly from beginning to end, can anyone help me.
ATABOY
ATABOY is offline   Reply With Quote
Old 02-27-2010, 11:54 AM   #2
Hoping you are referring to a mortarbed, and not actually thinset. A mortarbed is to lend support to the base/bottom of a tub or shower unit made of materials other than metal. These materials can often flex if not properly supported. This can cause cracking or breaking the seal around the unit. I use a 5 gallon bucket of premixed mortar. I measure how far the bottom of the tub/shower is (going to be) from the floor. Lay a sheet of plastic down to prevent the moisture from the mortar from ruining the flooring or subfloor material. Pour the mortar about 1/2" higher than the measurement from floor to tub/shower. If the unit has some bracing already built into it, pour between these supports. When you set the unit into the mortarbed, make sure you compress it into the mortar. You will now have a solid surface under the unit.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 10:30 AM
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 04:46 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Installing a new shower base frgwtchr Plumbing 2 08-17-2009 07:30 AM
How to install a preformed shower base Ironman Plumbing 2 01-15-2009 09:36 PM
