How To Plumb A Well System - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-29-2013, 10:26 PM   #1
How to plumb a well system
I have a very old house that we are doing a full remodel in, i am just starting supply lines for plumbing. There is a single pipe well pump and tank. My big question is why is there not a pressure switch on the tank? I have seen other systems setup this way as well but never thought anything of it.
BigBoost4g63 is offline   Reply With Quote
Old 04-29-2013, 11:28 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
The newer systems use a fiberglass bladder tanks with the pressure switch on the pump. the old galvanized holding tanks used a regulator that usually came off the side of the tank the to the switch on the pump.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-29-2013, 11:45 PM   #3
I guess i should have left the "old house" part out of this one since it really doesnt have anything to do with the question because it is a newer style bladder tank. I see what you based your answer off in my post though, so thanks.
So you will only see a pressure switch or regulator on old holding tanks, but if it is a bladder tank its good with it on the pump only right?
Old 04-30-2013, 06:53 AM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
Let me go back they still sell and use the galvanized tanks its a holding tank vs the bladder type which is a mix of pressurized air / water still the same result. bladder type seem to hold up better. one inlet vs one in one out.
Old 04-30-2013, 07:08 AM   #5
Rewards Points: 3,130
Not always. My system is only four years old, and I have a pressure switch mounted next to the tank that's in the crawl space. Gotta have something that tells the pump when to start and stop. It's possible your switch is inside the top of the well casing; mine was temporarily set up that way because we were living onsite in our RV while building the house. Also had a small temporary pressure tank, which is still buried up by the well. All that was disconnected when I plumbed the house.
If I recall (plumbers correct me if this is wrong), the system works best when the pressure switch is close to where the water is being used.
Old low voltage lighting system - switches stopped working. zepman Electrical 14 02-17-2016 07:18 PM
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 11:56 AM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 07:17 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 03:26 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
