-   -   How to plumb a well system (http://www.diychatroom.com/f7/how-plumb-well-system-178415/)
BigBoost4g63 04-29-2013 10:26 PM
I have a very old house that we are doing a full remodel in, i am just starting supply lines for plumbing. There is a single pipe well pump and tank. My big question is why is there not a pressure switch on the tank? I have seen other systems setup this way as well but never thought anything of it.
Javiles 04-29-2013 11:28 PM
The newer systems use a fiberglass bladder tanks with the pressure switch on the pump. the old galvanized holding tanks used a regulator that usually came off the side of the tank the to the switch on the pump.
BigBoost4g63 04-29-2013 11:45 PM
I guess i should have left the "old house" part out of this one since it really doesnt have anything to do with the question because it is a newer style bladder tank. I see what you based your answer off in my post though, so thanks.
So you will only see a pressure switch or regulator on old holding tanks, but if it is a bladder tank its good with it on the pump only right?
Javiles 04-30-2013 06:53 AM
Let me go back they still sell and use the galvanized tanks its a holding tank vs the bladder type which is a mix of pressurized air / water still the same result. bladder type seem to hold up better. one inlet vs one in one out.
md2lgyk 04-30-2013 07:08 AM
Not always. My system is only four years old, and I have a pressure switch mounted next to the tank that's in the crawl space. Gotta have something that tells the pump when to start and stop. It's possible your switch is inside the top of the well casing; mine was temporarily set up that way because we were living onsite in our RV while building the house. Also had a small temporary pressure tank, which is still buried up by the well. All that was disconnected when I plumbed the house.
If I recall (plumbers correct me if this is wrong), the system works best when the pressure switch is close to where the water is being used.
