How To Permanently Resolve Sulfur/rotten Egg Smell In Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 11:06 AM   #1
How to permanently resolve sulfur/rotten egg smell in water
Good morning.
I have the dreaded rotten egg/sulfur smell in my hot water. It was diagnosed as a bad rod in my hot water heater. However, I can eliminate the smell if I change the whole-house water filter every 3-4 weeks. I've been using the el-cheapo ones that should last for months.
Would that suggest the problem ISN'T the hot water heater, but rather an issue with the well water on the whole? I can't wrap my head around why the filter reduces the smell, but for limited times.
Any thoughts?
Additional info: I'm on a well, I'm living solo in the house for 4/7 days during the week for now, so I don't run water that often, and the water tested fine when analysis was run. I smell nothing when running cold water.
Thanks in advance.
cne24 is offline   Reply With Quote
Old 02-24-2013, 11:11 AM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 984
On more than one occasion we've had to replace the water heater and treat and flush the lines in the house, depends how fare the bacteria has spread through the system. providing it originated at the water heater.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-24-2013, 11:14 AM   #3
Thanks for the reply. The heater is 15 years old, so that could be the culprit. Like I said, I don't get how the filter can eliminate the smell for a period of time, since I didn't think that was a benefit of them. Though I suppose I shouldn't complain.
Thanks,
Chris
Old 02-24-2013, 11:16 AM   #4
Rewards Points: 12,830
•Flush water heater
•Using a hydrogen peroxide solution of 2 pints 3% peroxide to 40 gallons of water, treat tank and run some of the solution into water lines.
•Let peroxide solution set in tank and pipes for 2 hours. Solution is not toxic and requires no rinsing.
•If problem persists, replace anode with a zinc-alloy anode.
•If problem still remains, replace water heater with a plastic lined tank type.
Old 02-24-2013, 11:33 AM   #5
Thanks for the reply, Joe. I'll try the treatment first. I think I'd have trouble replacing the rod due to clearance issues in my basement (tilting the heater to remove/replace the rod) but will give it a shot if needed.
Sounds like all signs point to the water heater ... appreciate the confirmation.
Old 02-24-2013, 11:42 AM   #6
It's not going to ma tter if you have to bend the old one coming out. You can get a new one that's made in 2, pieces.
http://www.bing.com/images/search?q=...ectedIndex=240
Tags
hot water heater , sulfur , well water
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Sump pit smell and water color chsitko Plumbing 6 12-02-2010 03:28 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
