How To Outline The 1 1/2" PVC Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2007, 12:26 PM   #1
How to outline the 1 1/2" PVC drain
I'm in the process of replacing some galvanized pipe with PVC, but I'm unsure of the best way to run the drain.
A shower drain of 1 1/2" galvanized pipe runs with a couple of smaller 1/8 bends and then makes a 90 degree bend before a vertical sink drain of 1 1/4" pipe is connected to this line , which then runs about 4 feet before it connects to the main stack.
I have replaced the 1 1/4" sink drain with a 1 1/2" PVC and I now need to connect the shower drain and the vertical sink drain.
Is it ok to "remove" the 1/8 bends and just run a straight 1 1/2" PVC then make it turn 90 degrees as the sink drain is connected?
Not sure if a 90 degree turn is too much because the sink drain is in the same spot. The drain is horizontal with a slope of probably 1/4" per foot.
A poor drawing is attached.
By the way, I cannot replace all of the galvanized pipe due to space issues.
Thanks!
How to outline the 1 1/2" PVC drain-drain-changes.jpg
froddan is offline   Reply With Quote
Old 07-18-2007, 02:08 PM   #2
I'd keep the cleanout on the end of the line.....................
mdlbldrmatt135 is offline   Reply With Quote
Old 07-18-2007, 02:48 PM   #3
Cleanout...
I forgot to mention that I am installing a Cleanout on the very bottom of the Vertical Sink Drain that will attach right by the old cleanout.
I would think this would be ok...
Thanks for the reply!
Old 07-18-2007, 07:10 PM   #4
2" for shower drain is required .
tzzzz216 is offline   Reply With Quote
Old 07-19-2007, 05:07 AM   #5
Maybe for New code. My house (built in the 40's) has a 1 1/2" one on it as well.
Old 07-23-2007, 08:39 PM   #6
How did you make out?
redline is offline   Reply With Quote
Old 07-24-2007, 03:15 AM   #7
Not completely done. I've finished everything with the sinks, which runs like a charm.
The drain from the tub-shower to the sinks was a little bit slow, so I decided to replace that entire run too....and I'm still working on it.
So far, so good I would have to say....I'll post some pictures of the final result
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
I am doing the happy dance..I Finally got the tub drain cleared, whew!!! Woodpecker Plumbing 20 06-09-2007 11:20 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
