How Often Do You Replace Your Plumbing Snake - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2009, 03:54 PM   #1
Rewards Points: 682
How often do you replace your plumbing snake
I have a 3/8" snake that I have been using with a drain cleaning machine for awhile. I was wondering if I should replace it. It looks in pretty good shape, but should one replace a snake after so many uses or so much time?
Thanks.
darsunt is offline   Reply With Quote
Old 10-07-2009, 09:21 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I only replace after a break or a serious kink
Have one machine that is 10 yrs old never replace cable
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-08-2009, 09:58 AM   #3
Rewards Points: 1,418
For the most part you should hear the snake turning in the pipe at all times.
An occasional short pause in the sound followed by a soft "sproing" is okay.
If you consistently get a pause in the sound and as you crank you feel it winding up and then you hear a loud "SPROING" then you are running the risk of kinking and ruining the snake. When snags of this kind start to develop it is time to start withdrawing the snake (continue cranking the same way, clockwise, if needed to get it out). Check what you caught and try again.
Once the snake gets severely kinked you will have trouble in the future avoiding a snag where it winds up under tension instead of make its way down the pipe.
Old 10-08-2009, 10:07 AM   #4
I always inspect the cable (and wipe it down) when returning it to the spool. I look for cracks and bad kinks. The reason is that I do not want a section of the snake to become part of a clog by breaking.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Stuck Snake frederick70 Plumbing 22 05-13-2009 06:01 PM
Should I replace all of the plumbing? Pics enclosed? twilightcall Plumbing 15 01-23-2008 09:50 AM
