How Much Space Around A Sump Pump? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2008, 02:01 PM   #1
How much space around a sump pump?
Our builder placed our sump pump under the basement stairs. The only entrance to it is through the unfinished basement bath. I would like to frame about 2' into that space for a linen closet. How much free space does the sump pump need around it?
QueenL is offline   Reply With Quote
Old 04-08-2008, 02:40 PM   #2
concretemasonry's Avatar
Rewards Points: 2,570
You enough space to get to the sump pit, clean it (if necessary), service the pump and possibly replace the pump.
Dick
concretemasonry is offline   Reply With Quote
Old 04-13-2008, 01:37 AM   #3
Registered User
Termite's Avatar
There are no code-based clearance requirements to a sump pump. The only thing that you need to do is maintain the pumps accessibility.
sump pump issue mikehende Plumbing 15 02-15-2008 07:36 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Sump Pump Concept Questions dshuster Plumbing 1 11-22-2007 09:47 PM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 04:08 PM
