How Much Improvement Upgrade 1/2" To 3/4" - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2009, 06:08 PM   #1
Rewards Points: 874
How much improvement upgrade 1/2" to 3/4"
Hi, it's me again;
I have been looking at all of the plumbing in the basement after having to replace a pretty good amount of old pipe after a leak last Saturday.
I am looking in the furnace room, where the water heater is also located.
It's a gas unit, 10yrs old. No problems with it yet, but I'm starting to think of ways I can improve the system when eventually it does need replacement.
One thing I am thinking of is removing all of the 1/2" pipe to the hot water heater, on both the cold and hot sides and replacing with 3/4".
Most of the major plumbing is already 3/4", but around the WH, it drops down to 1/2" copper. The fittings on the WH are 3/4".
How much of an improvement in hot water supply would I see by replaceing the 1/2" pipe with 3/4", including several 90 ells, and a couple of Tees.
There is approximately 4ft of 1/2" pipe in the cold supply to the WH, and about 3ft in the output side.
I'm thinking that perhaps there would be less of a decrease in hot water supply (shower suddenly turning cold) when the washing machine is using hot water for instance.
There seems to be less of a problem when cold water is used elsewhere in the house during a shower downstairs.
I'm also thinking of replacing the bath/shower faucet with a pressure regulating type.
Thanks for your advice/suggestions
FW
Ultrarunner2017 is offline   Reply With Quote
Old 03-19-2009, 05:53 AM   #2
Remodeling Contractor
replacing the bath/shower faucet with a pressure regulating type is what you need in this case.
Old 03-19-2009, 07:02 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Think about this. 3/4" pipe holds 2-1/2 times more water than 1/2". If you run 3/4" out of the water heater, you'll have to run 2-1/2 times more water until it gets hot at the point of use. Afterwards, 2-1/2 times more water that you've paid to heat is laying in the 3/4" pipe getting cold. Run 3/4 cold supply, then branch of to individual fixtures with 1/2". Run a separate hot supply to the washing machine from as close to the water heater as possible. Run 3/4" supply TO the water heater.
Old 03-19-2009, 08:41 AM   #4
Rewards Points: 874
Exactly my thoughts as I analyze the situation.
I had not thought about the wasted hot water though. Thanks for the good advice.
FW
400 Amp Upgrade / Transfer Switch AndrewF Electrical 50 07-04-2009 07:33 PM
Can I upgrade my main panel? MarkinTexas Electrical 8 01-22-2009 10:15 AM
Upgrade Meter Box Help BenJoeM Electrical 10 10-24-2008 10:58 AM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 04:23 PM
