Old 07-20-2009, 12:31 AM   #1
How might a pro handle this closet bend
problem solved!!!!!
t56tr is offline   Reply With Quote
Old 07-20-2009, 07:16 AM   #2
I am a remodeler, but usually leave major DWV plumbing changes to the pros. The toilet flange can be replaced and relocated at the same time for proper standoff. Easy to snap iron with the right tools. That would also solve the old rusted nipple problems. Sink should now be 1 1/2, while tub/shower should be 2". Old vents will likely not be OK as exist, upgrade to 1 1/2 if not already.
Those old houses are so much fun. I did a bathroom last year, plumbing was buried in 5-6" of concrete. I knew there was a dining room below, but thought I would never get to the bottom of that stuff.
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 11:48 AM
How to fit a closet bend in a 2x8 ceiling cavity benjamincall Plumbing 4 04-24-2009 05:36 PM
Toilet Leaks When Flushed - How to get at closet bend!! OldHouseNewProblem Plumbing 3 12-11-2008 07:24 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
Musty smell from closet after leak Musty General Discussion 2 09-10-2007 09:36 PM
