How Many Wraps Of Tape? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2012, 12:33 PM   #1
How many wraps of tape?
ON 1/2"iron pipe when putting a valve on. I wrapped 5 wraps, tightenEd like crazy and have a tiny drip. I'm considering it's too much tape. Anyway, what do you suggest? Thanks
schatzi is offline   Reply With Quote
Old 05-27-2012, 12:50 PM   #2
Rewards Points: 13,724
When ever possible I'd suggest getting rid of any old steel piping. At some point it's going to leak or close up on the inside.
Did you wire brush off the fitting before installing the valve.
If you use teflon pipe dope instead of tape you may have less leaks.
Two wraps should have done it.
Old 05-27-2012, 01:15 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 676
I never use tape by itself. I always use a good paste and a couple tape wraps.
Don't over tighten 1/2 valves- very easy to do.
Old 05-27-2012, 04:17 PM   #4
Rewards Points: 582
when you use tape 2-3 wraps is good just don't over tighten it.....maybe thats what you did...start over...try again..ben
Old 05-27-2012, 04:24 PM   #5
Homerepairguy's Avatar
Rewards Points: 998
Pipe dope on male threads, 3 wraps of teflon tape clockwise over the pipe dope, more pipe dope on top of teflon tape. Pipe dope on female threads "very" sparingly.
Pipe dope on male threads gets squeezed "out" of the joint so amount is not critical. Pipe dope on female threads get squeezed "into" the joint so should be applied sparingly.
A lot of work but always worked 100% with no leaks for me. Overkill? Probably but prefer to do it with no leaks the first time than have to redo to correct leaks.
HRG
Homerepairguy is offline   Reply With Quote
Scotch Edgelock Tape: My afternoon entertainment bokeh Painting 5 06-20-2011 09:17 PM
Tape Showing cougar01 Drywall & Plaster 3 03-09-2011 04:21 PM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 06:56 PM
