How Many Wraps Of Tape? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2012, 12:31 PM   #1
How many wraps of tape?
ON 1/2"iron pipe when putting a valve on. I wrapped 5 wraps, tightenEd like crazy and have a tiny drip. I'm considering it's too much tape. Anyway, what do you suggest? Thanks
schatzi is offline   Reply With Quote
Old 05-27-2012, 08:35 PM   #2
2-3 wraps is what I usually do.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
plummen (05-27-2012)
Old 05-27-2012, 08:37 PM   #3
Rewards Points: 152
I always give it 4 wraps and a skim of pipe dope on galv/iron pipe.
burnt03 is offline   Reply With Quote
Old 05-28-2012, 01:42 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
Is this new pipe or old pipe? I'm going to assume old......not very common to use iron for water in this day and age....
Just so you know....the teflon tape is not really there to seal the threads..but rather lub them up so that you can get more turns...and take it apart when you want. If you want to seal...pipe dope.
Most good pipe fitters use both...teflon to lub the threads....pipe dope to seal.
Old 05-28-2012, 10:42 PM   #5
Actually ddawg it's the other way around. Tape to seal & dope for lubrication.
Old 05-29-2012, 06:26 AM   #6
Rewards Points: 1,216
It's just to lubricate it, the threads are supposed to seal it.
11/2 turns 2 MAX.
COLDIRON is offline   Reply With Quote
Old 05-29-2012, 09:45 PM   #7
Rewards Points: 960
I think if you read the tape package instructions or contact the manufacturer, there will be quite specific instructions. I remember reading one and it told how many wraps to use, and specified doing the wraps in a "rotating, spiral manner". No joke.
cleveman is offline   Reply With Quote
Old 05-29-2012, 10:21 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 996
In 35 years never used it and till this day will not use it, a good quality pipe dope will be sufficient, unless you have excessive thread ware on the fitting or pipe, then guess what time for a re-pipe. or partial.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-29-2012, 11:07 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 676
11/2 turns 2 MAX.
If people really stopped and thought about how pipe threads are cut, there'd be less tape sold.
Old 05-30-2012, 01:55 AM   #10
JOATMON
ddawg16's Avatar
That is contrary to what our pipe fitters say....and we do a lot of plumbing....
Like eplumber says...if people knew how pipe threads were cut...they would use less tape....
The tape is there to reduce the friction so you can get more turns on the pipe...THAT is what really seals the connection...
I have tightened both tape covered threads and pipe dope threads...the taped threads are much easier...
The Following User Says Thank You to ddawg16 For This Useful Post:
COLDIRON (05-30-2012)
Scotch Edgelock Tape: My afternoon entertainment bokeh Painting 5 06-20-2011 09:17 PM
Tape Showing cougar01 Drywall & Plaster 3 03-09-2011 04:21 PM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 06:56 PM
