How Many/where To Drill Holes Sump Basin - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2011, 04:32 PM   #1
Rewards Points: 150
How many/where to drill holes sump basin
Im about to install my sump basin to collect ground water / drain tile system in basement, the pit i ordered has no pre drilled holes.
i know i need to drill a 4'' hole on each side for the drain tiles, but should i be drilling a bunch of little holes in the basin itself to collect additional water?
if so, should i not go above/below a certain area?
reccomended hole size?
spacing?
thanks
alecmcmahon is offline   Reply With Quote
Old 03-18-2011, 06:29 PM   #2
Civil Engineer
Rewards Points: 4,524
If the drain tiles serve the entire basement, no need for any additional holes in the pit. If the drain tiles do not cover the entire basement, they need to be extended so they do serve the basement.
Daniel Holzman is online now   Reply With Quote
Old 03-18-2011, 09:07 PM   #3
Rewards Points: 1,418
Drilling additional small (1/2") holes above the level of the 4 inch holes accomplishes nothing.
Drilling additional small (1/2") holes below the level of the 4 inch holes will allow desaturation of the soil below the level of the drain pipes but only for a few feet radius around the pit. This is optional. A slight hazard exists that mud may enter the pit through these additional holes.
Sump pump basin cover BlueBSH Building & Construction 6 06-25-2010 03:04 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Sump Basin Install Considerations Fire4Effect Building & Construction 3 08-05-2009 05:30 AM
What Can I Use to Permanently Fill Holes in Sump Pump "Poly" Tubing? kmcrawford111 Plumbing 12 06-27-2008 08:24 AM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
