How Many Fixtures On A Wet Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2013, 07:23 PM   #1
Rewards Points: 77
How many fixtures on a wet vent?
Hi there.
My bath room has (from left to right) a sink, toilet, and a tub. The vent pipe is connected to the sink (1.5") and runs out the roof. No other vents. As I understand it this makes it a wet vent. What I'm wondering is if I can add a wash box (for washing machine) in between the toilet and the sink. Sink and tub are only a few feet apart. Wash box will be added on other side of wall. Any advise very much appreciated. in ohio. Thanks.
nateo is offline   Reply With Quote
Old 01-04-2013, 07:36 PM   #2
By any code I'm aware of, what you have there is a properly vented lavatory and an unvented toilet and tub. A wet vent is supposed to be 2" minimum, and to be correct the tub drain would have to wye off the toilet drain (3"x 2" wye rolled above the centerline of the 3" run), and the lav drain/wet vent would have to wye off the tub drain (2" wye rolled above the centerline of the horizontal tub drain).
I think a 2" vent stack serving a laundry in the location you've decribed wouldn't hurt anything. That would make the 2" stack the (sort of/default) faux wet vent for the toilet and tub. Some jurisdictions (like mine) do not allow a washing machine drain to be used as a wet vent; some do.
Ishmael is offline   Reply With Quote
Old 01-04-2013, 07:48 PM   #3
Rewards Points: 630
is there any thing else draining into the 3 inch pipe thru out the whole house
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 01-04-2013, 07:54 PM   #4
Rewards Points: 77
Originally Posted by Ishmael View Post
By any code I'm aware of, what you have there is a properly vented lavatory and an unvented toilet and tub. A wet vent is supposed to be 2" minimum, and to be correct the tub drain would have to wye off the toilet drain (3"x 2" wye rolled above the centerline of the 3" run), and the lave drain/wet vent would have to wye off the tub drain (2" wye rolled above the centerline of the horizontal tub drain).
I'm starting to think there was no inspections when this house was build (2004) ha. Anywho...Sorry for the crude drawling..yes the lav is wyed off the toilet. So if I 90 down the trap arm (with no san tee & vent) am I asking for trouble?
Old 01-04-2013, 08:20 PM   #5
Rewards Points: 630
put a 3 inch wye on its side turn a 3 inch 90 up into wall cavity under floor reduce to a 2 inch then run up through floor into wall cavity then plumb it in as picture and the off top of t where wash machine trap is reduce to 1 1/2 vent run up above height of the sink a foot or more then run over to sink vent and ty into it with a sani t. now if i remember correctly the vent size should be 2 inch or larger the rest off the up off the t where sink vent and wash machine vent ty in together, but a 1 1/2 will work
http://newhome.michaelwardonline.com...-House-117.JPG
and get ready to hear how this is not code but it will work
Old 01-04-2013, 08:22 PM   #6
Yeah...that's asking for trouble. Run the vent up through the roof in 2". Then you'll be about half a step closer to code compliance.
Old 01-05-2013, 01:24 AM   #7
if it is piped like the drawing it is wrong anyway. the tub isn't vented properly
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 03:45 PM
New Roof marknok Roofing/Siding 4 08-06-2011 12:41 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
