How Many Bends Allowed For Water Heater Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2010, 10:55 PM   #1
Rewards Points: 101
How many bends allowed for water heater venting
Have a gas water heater. The venting uses a blower and a 3" PVC pipe to go about 9 feet to the wall. I need to move it because the pipe goes through the middle of the unfinished bathroom beside which I want to finish. I will need the equivalent of 3 or 4 90 degree angles on the vent to get it up into the ceiling and then to the wall. Is thee a general limit maybe by national code, or is it specific to model.
Also, if it is code, state code here is basically whatever national code us (national electric code, etc...).
wvphysics is offline   Reply With Quote
Old 06-28-2010, 10:00 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I am pretty sure it's model specific, since not all water heaters use the same blowers.
I don't do much in the way of gas heaters though, so hopefully someone else will chime in.
Journeyman Plumber
Old 06-28-2010, 10:18 AM   #3
Licensed Master Plumber
The installation directions will give you the exact number of bends and the total length of pipe allowed. You MUST follow the manufacturers directions here.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 06-28-2010, 10:20 AM   #4
Owner
LateralConcepts's Avatar
How old is the heater? My experience with Power Vent heaters is that they have lots of problems and are expensive to repair or replace. Typical lifespan on a water heater is 8-12 years. If it is around that age, I would replace it with an electric heater and eliminate the venting all together.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 06-28-2010, 09:37 PM   #5
What problems? Admittedly some brands are better than others but properly installed and serviced they will last as long as any water heating appliance.
Old 06-28-2010, 10:24 PM   #6
Rewards Points: 101
I don't have any problems with mine, just that the installer was too lazy to work around hvac ducting above it to go into the ceiling, instead he just ran it straight over through the unfinished bathroom. Found the manual and looks like the answer is I can do 3 90 degree long sweep elbows which should be sufficient.
Old 06-29-2010, 12:43 AM   #7
See.... it's all in the manual
Old 06-29-2010, 10:28 PM   #8
Rewards Points: 101
Now that I've found how many bends I can have, I have another question. Can any of the piping be horizontal? The easiest way for me to run the pipes is to have one 90 to go horizontally about 16" then another 90 to run it vertical the. The last 90 to runhorizontql thru the wall. The manual doesn't say anything about running horizontal, but does have a couple diagrams that show it running horizontal.
Old 06-29-2010, 10:37 PM   #9
Doing it myself
Alan's Avatar
Thats the reason for having a heater with a blower exhaust on it. If you didn't have the blower you'd be required to have the pipe in the vertical position only.
Journeyman Plumber
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Venting med. efficiency furnace and H2O heater thru wall? cbrc5eric Building & Construction 2 04-03-2010 12:07 AM
Hot Water Heater Venting...need suggestions flyhop Plumbing 11 01-27-2010 01:50 AM
Garage heater venting question brill0724 HVAC 1 12-09-2009 08:06 PM
Need Input For Venting a Unit Heater story HVAC 1 10-31-2009 05:36 PM
