How Many 90 Degrees Allowed - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2009, 08:19 PM   #1
Question
How many 90 degrees allowed
I am installing a new vanity in my basement. I am using 1 1/2 pvc pipe and the run is less than 5 ft. I need to put either 2 - 90 degree turns or 4 - 45 degree turns to tie into the existing drain in the concrete floor. I have vented this run with 2 in pvc. My question is, is there a limit to the number of 90 or 45 degree turns I am allowed to install in this run? Or is my only concern possible blockage down the road with the 90 degree turns? Thanks in advance for your help.
myfixdon is offline   Reply With Quote
Old 01-07-2009, 05:57 AM   #2
some codes require 2" vanity drains and as far how many 90's I wouldn't worry about it. Try to use long turn 90's whenever possible. You'll see the difference.
II Weeks is offline   Reply With Quote
Old 01-07-2009, 07:55 AM   #3
only on toilets 1 ,90 for toilet bend and 45s or y with 45 with clean out .for vanity run 2 in
metx is offline   Reply With Quote
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Boiler Heating not going above 62 degrees tvlfleming HVAC 12 02-07-2007 02:52 PM
Pigtail inside panel box. Code allowed? KUIPORNG Electrical 7 08-22-2006 03:45 PM
I NEED HELP.... Its 85 degrees in my bedroom :( CherryFab HVAC 13 06-18-2006 09:18 AM
