How Many 90 Degree Bends Can I Use? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2012, 11:10 AM   #1
How many 90 degree bends can I use?
Is this acceptable? It is for a bathroom sink. As you can see, the plumbing comes out of the floor. The vanity has exposed shelves and it would look terrible putting a hole through the vanity, so I am trying to go through the wall.
Ocelot is offline   Reply With Quote
Old 11-08-2012, 04:16 PM   #2
Rewards Points: 1,092
The drain system has zero problems, but where is the vent?
Old 11-08-2012, 05:08 PM   #3
I back tracked and put an AAV on the top, so now the last 90 going out of the wall is a tee with an AAV on top. I will be putting the vanity in front of it and drilling a couple inconspicuous holes to allow it to vent. Thanks!
Old 11-08-2012, 05:19 PM   #4
Rewards Points: 14,300
An AAV needs to be accessable.
Those supplys and drains should have been run though the wall not the floor.
Old 11-08-2012, 05:25 PM   #5
I know it. As a result I had to run the supply like I did the drain, entering the wall at the bottom and out by the waste drain. I cut out a section of the wall which will be hidden by the vainity, so I can still access the AAV by removing the vanity.
Old 11-08-2012, 09:07 PM   #6
Rewards Points: 636
also at least where i live you can not glue abs to pvc must stay all the same or convert with mechanical fitting
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 11-08-2012, 09:12 PM   #7
Still trying to figure out since your not going to use the old steel pipe why it was not just removed and new pipe ran in the same spots.
Old 11-08-2012, 09:49 PM   #8
Rewards Points: 582
that whole thing is illegal.... where i come from..ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (11-09-2012)
Old 11-08-2012, 09:53 PM   #9
Same here.
Old 11-08-2012, 10:27 PM   #10
It is actually black PVC. The exposed pipe was painted black to conceal it better under the vanity. As I said, an AAV was installed on the top with access, also acting as a clean out. The pipe you see in the wall is old gas pipe. It was cut off like that, which I found when I opened up the wall.
Old 11-08-2012, 10:47 PM   #11
Where not there to see it, but just from looking at the sizes and spacing, I highly doubt it was a gas line.
I'm seeing two supply lines and and an old drain line.
Old 11-08-2012, 10:54 PM   #12
All my supply lines in the house are copper. All my gas lines are steel. But your right, the spacing is too similar to water lines. ahh the joys of a 1920 house.
Old 11-08-2012, 11:08 PM   #13
Why would there be two gas lines" Why the larger line? And back in 1920's there was no copper lines for water pipes.
Old 11-08-2012, 11:15 PM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 904
I have piped the drain like you show and it passed inspection- sometimes structural stuff makes you get creative. AAV's are frowned on in my neck of the woods so I can't speak with a lot of experience but if you do it like this you should be good to go
consequences if patio awning has a 10 degree fall instead of 5 degree LabRatte Roofing/Siding 4 08-13-2012 04:39 PM
70 degree Supply Air ryanxo HVAC 60 07-17-2012 01:45 PM
135 degree crown molding cut jbeaulieu Carpentry 5 05-19-2011 04:30 PM
Best way to make 45 degree mitre jig BobS0327 Carpentry 7 09-21-2010 11:53 PM
Do conduit offsets count as bends? alvanos Electrical 7 02-25-2008 09:24 PM
