how to make a pressure balancing loop
ok. here's what i've come up with after exhaustive research 2 loops, 1 for each side(with 2 sprays each). each loop gets a supply in the middle of the loop. that way neither of the heads gets more supply than the other. seperate loops seems to be the way to go with each loop getting equal supply from a tee eqaully spaced from the valve. sounds ok to me. anyone have a better idea? think of a square, with the heads on the top and bottom surface. then the supply line comes in 1 of the side surfaces right in the middle. this is with the valve in betwwen the loops. looks like a pair of eyeglasses with the bridge being the valve. am i wrong? lots of views on this thread but no replies. come on pro's, help me here.
mike
