Old 10-04-2009, 01:51 AM   #1
Default How to make crap flow uphill
Considering adding an upstairs bathroom to an old house. Getting the drains over to the stack will be next to impossible (if only using gravity as a means of making them work). Is there a way to flush water against gravity so that tying into the stack is more easily accomplished? I have never seen or done anything like this, but I'm guessing the pros might have some thoughts. The house has an addition and tying in is going to be a challenge.
thanks
brokenhammer is offline   Reply With Quote
Old 10-04-2009, 08:17 AM   #2
only way is to use a basin and an ejector pump.
Bob Mariani is online now   Reply With Quote
Old 10-04-2009, 11:29 AM   #3
Only way to defeat gravity is with a pump. Sounds like you may need a Sani-flo toilet with a macerating pump.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-04-2009, 08:16 PM   #4
Building codes guy, Mod
thekctermite's Avatar
Yup, ejector pump.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 10-05-2009, 12:35 AM   #5
is a macerating pump the same as ejector pump?
Old 10-05-2009, 07:01 AM   #6
pretty much
More On This Topic
Multiple Dog Greetings
Multiple Dog Greetings by Expert Village
Often times with multiple dogs in one house it could make coming and going a little bit more stressful, a little bit more activity among the dogs so it is always good to develop a routine that you got so you can separate dogs when you leave that when you... Read More »
Hi. My name is David Bradshaw. I'm talking about the distribution of TV wirelessly around your home to different screens that you might have around your house. So now we're going to get right into the nuts and bolts of this and we're going to look at how... Read More »
Hi, this is Phil Coonrod on behalf of Expert Village. Today we're going to talk about how to beat Call of Duty 4 Modern Warfare. Call of Duty 4 Modern Warfare is a registered trademark of Activision. Accompanying which I have no affiliation. Okay we're... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
We take our 2 9s, our 2 red 9s and we combine them with this 8 and this 7, and this 5 to make a straight to the 10. Make a straight to the nine red (sorry about that) that's 5 6 7 8 9. Around to the left we have a flush the ace plays as itself, the ace... Read More »
How to make room for humidifier zunk HVAC 4 02-24-2009 07:00 AM
Anyone know how to make cafe doors? versatile1 Carpentry 3 08-01-2008 11:39 PM
Will rebuilding a vintage facuet make it low flow now? twilightcall Plumbing 1 06-14-2008 02:24 PM
Can a septic line make right angles? Randell Tarin Plumbing 7 01-26-2008 10:01 PM
Do they make this? Malcolm Roofing 3 10-14-2007 01:23 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
