#1 |
How long to heat the brass fitting
When sweating a brass fitting to a copper pipe, how long should you heat up the brass fitting before you move the flame to the joint where the copper pipe joins the brass fitting? I will probably be using map gas.
Thanks |
#2 |
I dunno 15-20 seconds? Never counted you just see the solder flow nicely and you know you got it.
You never really "heat the joint" you heat the object i.e. a fitting or valve at the thickest part, you want to draw solder into the joint, not just melt solder onto the joint. |
| Display Modes | |
| trane mod# twe060c15fdo no heat, help | itsme711 | HVAC | 1 | 01-21-2009 10:03 PM |
| New Thermostat- Heat comes on when on "Cool" | daviar | HVAC | 3 | 06-29-2008 06:24 PM |
| Electric Heat pump in New England? | jzinckgra | HVAC | 7 | 05-22-2008 03:02 PM |
| Steam heat vs Hot water heat | helpless handyman | HVAC | 5 | 10-03-2006 09:57 PM |
| Long range HVAC planning. | dalesd | HVAC | 2 | 02-23-2006 01:37 PM |
