-   -   How long to heat the brass fitting (http://www.diychatroom.com/f7/how-long-heat-brass-fitting-49435/)
jgs1951 07-22-2009 06:55 PM
When sweating a brass fitting to a copper pipe, how long should you heat up the brass fitting before you move the flame to the joint where the copper pipe joins the brass fitting? I will probably be using map gas.
johnnyboy 07-22-2009 07:20 PM
I dunno 15-20 seconds? Never counted you just see the solder flow nicely and you know you got it.
You never really "heat the joint" you heat the object i.e. a fitting or valve at the thickest part, you want to draw solder into the joint, not just melt solder onto the joint.
jgs1951 07-22-2009 09:19 PM
Thanks Johnnyboy, you saved me from making a mistake
