How Long After Soldering Copper Fitting Do You Need To Wait B4 You Can Run Water Thru - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-21-2013, 07:22 PM   #1
Rewards Points: 150
How long after soldering copper fitting do you need to wait B4 you can run water thru
I just did my first copper pipe soldering, how long do you have to wait before you can water test the fitting?
Arsinek is offline   Reply With Quote
Old 04-21-2013, 07:28 PM   #2
joed's Avatar
Rewards Points: 11,992
Long enough for the solder to cool which is about 30 seconds after you take away the heat.
Old 04-21-2013, 07:48 PM   #3
Rewards Points: 150
Wow, so after like 1 minute I can run water through the connection I just made?
What about pressure on the fitting? Like how long until I can treat it like a fitting thats been there for a year?
Old 04-21-2013, 08:06 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 450
As soon as you put water in it.
Old 04-21-2013, 08:55 PM   #5
Rewards Points: 150
Well Im done. One connection was squirting water and the other had a stream running down it. I did a bunch of researching before trying and I still couldnt get it so Im just going to pay someone to put some copper to pvc fittings on and go with pvc.
Old 04-21-2013, 08:59 PM   #6
Not related but still funny anyway.Yesterday i was doing some pluming for a new toilet nile and just finished soldering the cap on the end of the toilet line and forgot to wait till it to cool and turned the supply on while on my knees and the cap shot right off like a bullet and hit me square in the balls.Hurt like hell but i learned from that one.I usually use a wet rag to wipe every joint i make right after i solder it.It cools it down and helps the pipes from turning green in time.
shakey0818 is offline   Reply With Quote
The Following User Says Thank You to shakey0818 For This Useful Post:
bbo (04-22-2013)
Old 04-21-2013, 09:05 PM   #7
Plumber
Rewards Points: 450
The choice is yours if you want to pay someone, but PVC is not to be used inside a house on domestic water. Use CPVC or PEX, or copper and push fit fittings
Old 04-21-2013, 09:16 PM   #8
Rewards Points: 194
I had to laugh. This is a lot funnier when it happens to someone else.
Larryh86GT is offline   Reply With Quote
The Following 2 Users Say Thank You to Larryh86GT For This Useful Post:
RickyBobby (04-24-2013), RWolff (04-22-2013)
Old 04-21-2013, 09:17 PM   #9
Rewards Points: 150
CPVC, is what I meant.
Old 04-21-2013, 09:17 PM   #10
Buy a few shark bites.
jsbuilders is offline   Reply With Quote
Old 04-21-2013, 09:19 PM   #11
Rewards Points: 150
I had that thought. But whats the lifespan on those things?
Old 04-21-2013, 09:24 PM   #12
Rewards Points: 6,652
Umm yes, it is within a minute, that you can turn back on the water. It will be as good as any soldered connection, that is a year, two, five, twenty, etc., as long as the person that does it properly knows how to sweat a joint properly.
Old 04-21-2013, 09:26 PM   #13
Copper turns green, which is called Patna, which is a natural process. Has nothing to do with cooling it down after soldering a joint.
Old 04-21-2013, 09:35 PM   #14
Ty for clearing this up for me i allways thought the flux helped it turn green faster when not wiped.
Old 04-21-2013, 09:42 PM   #15
25 years, I believe.
Bunch of random quick questions about soldering, faucets, etc amodoko Plumbing 11 10-29-2012 03:15 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
undersink, integrated hot water booster- too long a run from hot water heater msavage Plumbing 7 06-01-2010 11:15 PM
