-   -   How long after soldering copper fitting do you need to wait B4 you can run water thru (http://www.diychatroom.com/f7/how-long-after-soldering-copper-fitting-do-you-need-wait-b4-you-can-run-water-thru-177762/)
Arsinek 04-21-2013 07:22 PM
I just did my first copper pipe soldering, how long do you have to wait before you can water test the fitting?
joed 04-21-2013 07:28 PM
Long enough for the solder to cool which is about 30 seconds after you take away the heat.
Arsinek 04-21-2013 07:48 PM
Wow, so after like 1 minute I can run water through the connection I just made?
What about pressure on the fitting? Like how long until I can treat it like a fitting thats been there for a year?
TheEplumber 04-21-2013 08:06 PM
199 Attachment(s)
As soon as you put water in it.
Arsinek 04-21-2013 08:55 PM
Well Im done. One connection was squirting water and the other had a stream running down it. I did a bunch of researching before trying and I still couldnt get it so Im just going to pay someone to put some copper to pvc fittings on and go with pvc.
shakey0818 04-21-2013 08:59 PM
Not related but still funny anyway.Yesterday i was doing some pluming for a new toilet nile and just finished soldering the cap on the end of the toilet line and forgot to wait till it to cool and turned the supply on while on my knees and the cap shot right off like a bullet and hit me square in the balls.Hurt like hell but i learned from that one.I usually use a wet rag to wipe every joint i make right after i solder it.It cools it down and helps the pipes from turning green in time.
TheEplumber 04-21-2013 09:05 PM
199 Attachment(s)
The choice is yours if you want to pay someone, but PVC is not to be used inside a house on domestic water. Use CPVC or PEX, or copper and push fit fittings
Larryh86GT 04-21-2013 09:16 PM
I had to laugh. This is a lot funnier when it happens to someone else. :laughing:
Arsinek 04-21-2013 09:17 PM
CPVC, is what I meant.
jsbuilders 04-21-2013 09:17 PM
Buy a few shark bites.
Arsinek 04-21-2013 09:19 PM
I had that thought. But whats the lifespan on those things?
gregzoll 04-21-2013 09:24 PM
Umm yes, it is within a minute, that you can turn back on the water. It will be as good as any soldered connection, that is a year, two, five, twenty, etc., as long as the person that does it properly knows how to sweat a joint properly.
gregzoll 04-21-2013 09:26 PM
Copper turns green, which is called Patna, which is a natural process. Has nothing to do with cooling it down after soldering a joint.
shakey0818 04-21-2013 09:35 PM
Ty for clearing this up for me i allways thought the flux helped it turn green faster when not wiped.
jsbuilders 04-21-2013 09:42 PM
25 years, I believe.
