How To Keep Auger Snake From Rusting In Drum? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2009, 09:30 PM   #1
Rewards Points: 682
How to keep auger snake from rusting in drum?
How do you keep the snake in the drum of a drain cleaning machine from rusting? Is spraying it with WD 40 enough?
Also I've read you are supposed to clean the snake after you use it, but I don't think I've ever seen a plumber actually clean the cable after clearing one of our drains.
darsunt is offline   Reply With Quote
Old 08-03-2009, 09:41 PM   #2
I always wiped the cable down as I returned it to the drum. Since I used it a lot, it didn't really have a chance to get anything but surface rust on it. I would use a regular oil (thinly) on it if it will not be used for a period of time. Holding a rag with oil on it around the cable while returning it will do the trick.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-03-2009, 09:42 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
You pull the cable out of the drum and rub it down with oil. Its rather messy. I get an apprentice to do it. No, you probably wont see a plumber clean/oil the cable while at your place of business and/or residence. It usually happens back at the shop.
JDC is offline   Reply With Quote
Old 08-04-2009, 11:10 PM   #4
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
clean cable every time
Before I pull it out of any drain. I hook up a hose to the hot water heater and flush it in the drain , then wipe it before it go's back in the drum. After I use a little wd-40 , it works great and then I dont touch it intill the next little nasty.
lonsplumbing is offline   Reply With Quote
Old 05-26-2012, 07:46 AM   #5
In able to keep the auger from rusting, you have to clean it every after use. The first thing that you should do is to soak it in hot water with detergent. Then, wear your protective gloves and scrub it and let it dry after. Always do that procedure after using the auger snake.
___________________________
plumbing
kent0405 is offline   Reply With Quote
Drum trap, best to replace them? diymonkey Plumbing 4 06-04-2009 08:14 AM
Stuck Snake frederick70 Plumbing 22 05-13-2009 05:01 PM
How to use a snake to clear a drain? Nestor_Kelebay Plumbing 11 12-09-2008 04:45 PM
Clogged Shower Drain..Auger Bent! Too Big?? bswain06 Plumbing 2 05-12-2008 04:03 PM
