Old 02-18-2013, 08:04 AM   #1
DIY Enthusiast
How to install Watts N45BU M1 pressure reducing valve
Hello all,
I intend to install the following Watts pressure reducing valve and don't understand the connection style used on the right (low pressure) side of the valve in the image below. The connection on the left (high pressure) side of the valve is a 3/4" female NPT connection. Looking at the valve I have, the low pressure side seems to be a union connection that requires an o-ring (same as on the high-pressure side) - I'm not familiar with this type of connection and can't find any mention of how to connect to it on the Watts site or the valve instructions.
Thanks in advance for the help!
ED
Ed G is offline   Reply With Quote
Old 02-18-2013, 08:24 AM   #2
The one in the picture is missing the adaptor that's bought seperatly.
http://media.wattswater.com/1915390.pdf
There at least three differant styles avalible.
Shark Bite
A Pex, Barded
And slip fit copper in 2, differant sizes.
You can also buy a pressure regulator that has Shark Bites on both ends so no soldering is needed.
Old 02-18-2013, 10:25 AM   #3
Doing it myself
Alan's Avatar
It's not missing anything.
It's threaded FIP on the inside.
The union can be swapped to either end, which is why the threads look funky.
Every regulator i've ever installed only comes with one union nut.
Both ends have union thread on the outside and iron pipe threads on the inside.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
TheEplumber (02-18-2013)
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 08:07 AM
How to change a bad pressure relief valve maddog1 Plumbing 2 12-17-2012 01:46 PM
Pressure Relief Valve Leaking new_DIY Plumbing 10 10-04-2012 11:24 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Replacing a Pressure Relief Valve for a Boiler multiphrenic HVAC 18 11-30-2011 12:16 PM
