Can i use the horizontal cold water line to the washer. if so, what do i need? is it difficult for a novice or should a plumber be called?
the washer it is the closest cold water horizontal line. my sink is on the opposite side of the kitchen so i cannot use the sink and i have no basement. any ideas? i just bought this whirlpool fridge (really nice) with r/o water & ice maker.:thumbup: at first it seemed as if the previous owners had the copper pipe which runs through the wall at the back of the fridge hooked up to a water source but when we attached the fridge to the line from the wall and turned on the valve, no water came through. it was then that we discovered that the copper pipe had been run through the utility room but was cut off and tapped shut at some point. a real bummer and aggravating as the previous owners had their fridge water dispenser/ice maker hooked up when we did our first and final walk-through prior to closing on the home. thanks for any/all input.:whistling2:
