How To Install Tub Drain Where Toilet Once Set? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2010, 01:52 PM   #1
How to install tub drain where toilet once set?
I am working on concrete slab. The only location for placement of tub is in location where toilet once set. The distance from the front of the tub to the opening in the floor where the toilet once set is greater than the tub drain. Can someone help me?
plumbingidiot is offline   Reply With Quote
Old 01-03-2010, 02:32 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,272
You will have to bust out the concrete. The problem is the toilet has no trap and the tub will require one. Break out enough concrete to access the existing toilet piping (3 or 4 inch) reduce down to inch and half (or 2) and install a trap for your tub. If you connect the tub to the existing toilet drain you will get sewer gas from the tub. It will stink and it is dangerous.
Coastal South Carolina
Old 01-03-2010, 04:54 PM   #3
Thank you! I was hoping to keep from tearing up the concrete, but what you suggested makes sense. I appreciate the help!!
toilet drain is too close to the wall in the basement Kirock17 Plumbing 15 02-24-2010 07:07 AM
Toilet Drain Question md2lgyk Plumbing 3 08-04-2009 11:01 PM
toilet drain pipe is crooked on new construction smcmurrey Plumbing 5 12-24-2008 08:32 AM
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 07:07 AM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
