| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Plumbing and Drain Tips for Bathroom Installation
by Expert Village
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
How to Repair a Wall With an Aluminum Patch
by eHow.com
A small hole in a wall is an unsightly nuisance. If the hole is less than 3 inches in diameter, you can easily repair it with an aluminum patch kit. Repair kits typically come with a 4-by-4 inch adhesive aluminum patch, spackling compound, sandpaper and... Read More »
How to Spackle Interior Walls
by Expert Village
Hello! My name is Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Okay now, we're to the preparation part of spackling. When you spackle you do want to have yourself a good flex blade. It's a little different from a... Read More »
How to Install Barrel Cap Trim
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Barrel cap trim is installed from the bottom up course to course with the panels. Install the end disc, position the first cap on the rig with the rear... Read More »
How to Patch Holes in the Wall
by Expert Village
Hi. I'm Bobby Hester on behalf of Expert Village. In this series we're going to show you how to hang big pictures, small pictures and every size in between. We're going to show you out to use hangers and we're going to show you how to quickly and easily... Read More »
