How To Install A Fiberglass Bathtub? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2010, 06:17 AM   #1
How to install a fiberglass bathtub?
I need to know how to install a fibreglass bathtub. Some say you need to install it with sand and others say with sement. Please help!!!
sonjan is offline   Reply With Quote
Old 03-22-2010, 07:00 AM   #2
Many tubs require a formable base to support the bottom. Check manufacturers recommendations.
Old 03-22-2010, 09:44 AM   #3
Household Handyman
Rewards Points: 1,408
Bill's correct. But do put some type of base under the tub. David
Old 03-22-2010, 10:41 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
thinset seems to work good
plummen is offline   Reply With Quote
Old 03-23-2010, 02:56 AM   #5
Rewards Points: 1,016
Typically recommended to have a bed or thinset or similar under the tub. Else it may well have movement and give when you stand in it. A search here should provide additional details.
Old 04-05-2010, 10:06 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
We use "High strength mortar mix" Sometimes the distance between the floor and the deck is too great. Thinset only works in about 1/4" thickness (hence the name thinset)
Journeyman Plumber
Old 04-05-2010, 06:59 PM   #7
Rewards Points: 262
That's the first time I've heard of that Alan, makes sense though. Thanks.
Jim F is offline   Reply With Quote
Bathtub Drain Assembly Install When No Access? thebigsee Plumbing 5 01-28-2010 12:02 AM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 08:48 PM
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 08:56 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Can I install 3/4" HW on top of the rolled floor membrane there now? davevarga Flooring 3 03-09-2008 11:16 PM
