-   -   How to install a fiberglass bathtub? (http://www.diychatroom.com/f7/how-install-fiberglass-bathtub-67320/)
sonjan 03-22-2010 05:17 AM
I need to know how to install a fibreglass bathtub. Some say you need to install it with sand and others say with sement. Please help!!!
Just Bill 03-22-2010 06:00 AM
Many tubs require a formable base to support the bottom. Check manufacturers recommendations.
Thurman 03-22-2010 08:44 AM
Bill's correct. But do put some type of base under the tub. David
plummen 03-22-2010 09:41 PM
thinset seems to work good
vsheetz 03-23-2010 01:56 AM
Typically recommended to have a bed or thinset or similar under the tub. Else it may well have movement and give when you stand in it. A search here should provide additional details.
Alan 04-05-2010 09:06 AM
We use "High strength mortar mix" Sometimes the distance between the floor and the deck is too great. Thinset only works in about 1/4" thickness (hence the name thinset)
Jim F 04-05-2010 05:59 PM
That's the first time I've heard of that Alan, makes sense though. Thanks.
