How To Insatll Water Supply? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2009, 05:56 PM   #1
how to insatll water supply?
im trying to put in my water supply at the back of the toilet,the plumber left the copper pipe sticking out of the wall about 6"Whats my next step ? cut the pipe? but then do i need thread on the pipe so i can screw in the next piece for the water supply,or is there a certain piece of material that comes with it when i buy it.Whats my next step
ron0805 is offline   Reply With Quote
Old 10-12-2009, 07:10 PM   #2
Residential Contractor
You need to turn off your main water valve, drain down the water system. (Open faucets on all levels) Then cut the pipe with a tubing cutter at approximately 3" from the wall. (Closer if you want a cleaner look).
Buy a 1/2" compression angle stop, and an escutcheon. You dont need threads, the angle stop will attach to the copper pipe and mechanically tighten. You will need 2 crescent wrenches.
Before you put on the angle stop, place the escutcheon (shiny metal ring that covers hole) on the copper pipe and slide it back to the wall.
For best results, clean about an inch of the pipe next to your cut with an emery cloth so it is shiny.
You will also need a toilet supply line that will connect from the angle stop to the toilet.
All Home Depot stores and others carry these things, and the staff should be able to demonstrate how it all works.
rselectric1 is offline   Reply With Quote
Old 10-12-2009, 07:44 PM   #3
[quote=rselectric1;339804]You need to turn off your main water valve, drain down the water system. (Open faucets on all levels) Then cut the pipe with a tubing cutter at approximately 3" from the wall. (Closer if you want a cleaner look).
All Home Depot stores and others carry these things, and the staff should be able to demonstrate how it all works.[/quote
thx for ur advice ill do it tommorrow
Old 10-12-2009, 07:47 PM   #4
Good luck and be patient with it.
water supply layout wglord Plumbing 1 07-13-2009 12:07 PM
City water supply to meter in house Watership Down Plumbing 2 07-08-2009 10:39 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
Can water supply pipes be PVC?? i need general help... hallbum Plumbing 5 12-10-2005 01:22 AM
