How To Increase Water Pressure? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2010, 07:40 PM   #16
Owner
LateralConcepts's Avatar
Originally Posted by Plumber26 View Post
if your house is a 1930 you likely have galvanized pipes which get rusty on the inside. Sometimes they get rusty enough to even let no water at all into a fixture(s). My suggestion would be to identify which type of plumbing you have in your house, in your walls, in your yard, and what the material is that connects to your meter on the city's end. If any galvanized pipes exist, be ready to replace them if you really want to solve the problem.
Glad I'm not the only one that doesn't pay attention
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 12-30-2010, 08:28 PM   #17
Picky Plumber
Yes, I AM an idiot!
Plumber26 is offline   Reply With Quote
Old 03-01-2011, 07:07 AM   #18
Yes, I AM an idiot!
I beg to differ. We, who are experiencing the same problem, years after the original poster, appreciate your input and will read these threads to the end whether or not they span years or days.
Keep the input coming!
stnemason is offline   Reply With Quote
Old 03-01-2011, 08:33 AM   #19
Rewards Points: 1,514
Even copper pipes can develop arteriosclerosis in which case you would have to replace them.
Unfortunately there is no easy way to tell where along the pipe the problem is at its worst.
Tankless water heating coils also develop this problem in which case the gallons per minute goes down drastically. Taking the coil out and having it flushed with acid sometimes fixes that problem.
Old 03-01-2011, 09:03 AM   #20
Rewards Points: 530
I agree with Plumber.
I used to wonder why the hot water line seemed to be more prone to clogging.
I think it is the fact that normally there is no holding tank for the cold. The cold tends to get flushed every time the cold water is used reducing the effect of hard water, etc..
Hot water tanks get sediment that can get disturbed and flushed into the lines where it can sit and build up, especially in galvanized piping, imo.
If you have ever move an old galvanized hot water line, you can see some that will be almost closed up if not completely closed off.
Dependent on the routing of the hot water line and the types of ells used, it would be interesting to see if street elbows only on the hot water line might help a little with the pressure drop. Might not be noticeable, just a thought, not a real permanent fix.
Old 03-01-2011, 10:56 PM   #21
how
Rewards Points: 1,104
First make sure your house water shut off valve is fully open.(Fully turned Counterclockwise)
Do you have a pressure reducing valve in your house near your main water shut off and probably immediately after the inside shut off to your front yard hose line. If so, it may be able to be adjusted to give youself more pressure. Adjusting much over 75 psi will shorten the lifespan of your hot water tank as well as cause washing/dish washer solinoid issues.
If your house had galv piping and was later upgraded to copper, often a few awkward to get to galv fittings may have been left in place which is restricting your water flow. Walls get broken open to fix this.
You won't have 3/8 piping to worry about. I recommend at least starting with changing your lines to 3/4" from the supply to the hot water tank.
how is offline   Reply With Quote
Old 10-30-2011, 03:00 PM   #22
so many factors....
First thing to consider is the main coming from the street. Here in buffalo the usual is galvanized and copper. Sometimes I even run in to lead coming from the street. Obviously copper is the best. Lead is unbelievably horrible. Galvanized is most constricting due to corrosion. If you have a functioning shut off before the meter I suggest getting a 3/4 male 1inch shark bite fitting. From there rerun your main in 1 inch pex pipe. This reduces freezing pipes in cold climates. The 1 inch pex is in my opinion carries better pressure than 3/4 copper. Less likely to get torn out by crack heads too. You next need to consider if your meter isn't constricting flow. The water authority will upgrade in most cases. Now continue your cold main in 1 " pex. Tee off your hot water tank in 3/4 red pex to lessen confusion. A smart thing to do if possible is to tee into where you want your most pressure. I always take 1 x 1/2 tee off the cold main. 3/4 x 1/2 off the hot in most cases. Some times 3/4 tee for spots in need of more pressure. This should help but it takes some real skill and of course luck. I'm not fond of boosters bit in some cases they are needed. Now a days the tools are more affordable than ever and us plumbers hate it but we can say thanks be to the interweb.
Your welcome,
Kindwon
kindwon is offline   Reply With Quote
Old 01-09-2012, 10:29 PM   #23
Question
Increasing Water Pressure
Can you increase my shower water pressure by increasing the copper pipe size. I have 1/2 risers coming off 3/4 inch pipes going into the shower and tub on & off control.
Also I notice the pipe going from the on/off to the shower outlet is a 1/2 inch pipe. Will this negate the increased flow/pressure?
My theory is more flow means more pressure.
Jcrawf1000 is offline   Reply With Quote
Old 01-09-2012, 11:22 PM   #24
Plumber
TheEplumber's Avatar
Rewards Points: 684
Increasing pipe size won't increase pressure
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
hummer4x4guy (01-09-2012), Jcrawf1000 (01-10-2012)
Old 09-06-2012, 02:25 AM   #25
Originally Posted by AllGoNoShow View Post
I have an old 1930 house with copper plumbing lines (they are all about 3/8 or 1/2). I have one full bathroom and whenever someone in the house uses the kitchen sink/dishwasher/clothes washer when you take a shower, the pressure will drop and the water turns cold as if there is not enough hot water getting up to the shower. I'm assuming just increasing the line pressure will allow for hot water to get to both the shower and any other appliances that might be running.
Now, the question is, how do I go about increasing the line pressure, and can i even do this? Thanks!
Nick
http://www.ronhazelton.com/projects/...e_in_your_home
cyberoptiq is offline   Reply With Quote
Old 09-06-2012, 10:50 AM   #26
how
What is your current pressure?
You should also check if the street valve is fully open, same with the water shut off to your home, that you don't have a semi clogged filter in your pressure reducing valve, that your water valve to HWT is fully open, that you don't have any old galv iron fittings mixed with your copper, etc..
In otherwords eliminate the chance it's a water flow restriction.
Old 09-06-2012, 07:22 PM   #27
post #1 was at 02-21-2007, 04:20 PM. I'm i to late to help?
1950home is offline   Reply With Quote
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 02:32 PM
water pressure problem rgmetro Plumbing 6 04-09-2007 03:57 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 09:04 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 06:55 PM
