How High Above Sub-floor Should Pipe For Toilet Flange Be Left When Tiling? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-22-2012, 04:08 PM   #1
How high above sub-floor should pipe for toilet flange be left when tiling?
We're going to install a tile floor over Ditra in our remodel in progress bathroom. We have 4" abs pipe going up to the toilet and plan to install a flange that slides inside the 4" abs flange that installs inside the pipe. It's an Oatley with a stainless steel ring and knock out center. The plumber who installed the piping cut the pipe off flush with the plywood sub-floor.
My concern is that the flange fitting with a typical tapered interference fit will not "glue up" properly when installed on top of tile another 1/2" of so above the sub-floor. When I dry test fit the flange 1/2" from seated it seems very loose and only comes tightish when seated.
It's not too late to go down below, cut off the 4" abs, insert a coupler and add a longer piece above. Does that sound like a good ideal or might one of the expansion based flanges be a better idea. Install tile slide in flange. Tighten up expansion screws. set toilet and be done?
Thanks for any informed replies
SG
SciGuy is offline   Reply With Quote
Old 10-22-2012, 04:17 PM   #2
Rewards Points: 12,878
Install one like this and it will be more then long enough and can be slid out if the floor ever needs to be redone.
http://www.bing.com/images/search?q=...794983&first=1
jaydevries (10-22-2012)
Re-cementing around Toilet Flange & Flange installation for Tiling Floor crayola110 Plumbing 7 09-22-2012 01:02 AM
Installing flange over uneven drain pipe cburke517 Plumbing 5 07-30-2012 05:40 PM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
Tiling around tub with very wide flange petsparkle Kitchen & Bath Remodeling 3 04-20-2009 04:53 PM
