How The Hex Do I Go From 1/2 Or 3/4 Pex To My 1/4 Icemaker - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2012, 11:38 PM   #1
Rewards Points: 55
How the hex do I go from 1/2 or 3/4 Pex to my 1/4 icemaker
I have 1/2 and 3/4 Pex in the basement and clean runs to the fridge. I can easily get myself where I need to go from 1/2 pex to my 1/4 supply line.
I want to use snakebites so I do not need to buy a crimper. Problem is I cannot find a snakebite to go from 1/2 to pex with something threaded for 1/4.
What am I missing?
I see this and it seems like close to what I need, but snakebite on the 1/2!
jkeuning is offline   Reply With Quote
Old 06-23-2012, 07:16 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
What am I missing?
Use a compression stop designed for pex
Old 06-23-2012, 02:33 PM   #3
You need a male thread adapter by snake bite fitting, that you can thread into that shutoff valve.
Remember to use teflon tape and pipe dope when you thread the fitting into the shutoff.
Pmmcgillis is offline   Reply With Quote
Old 07-15-2012, 02:00 PM   #4
Rewards Points: 55
Found the part I need. Thanks for the info!
sharkbite 23337-0000lf
http://bit.ly/P8gi50
Icemaker Diagnosis Help SPS-1 Appliances 3 11-12-2011 10:32 AM
How do you hook up a water line for in icemaker? kennykenny Plumbing 8 06-22-2010 04:23 PM
Kenmore icemaker problem bikercraig Appliances 1 08-12-2009 09:12 PM
whirlpool icemaker wiring question dannyb Appliances 3 03-28-2009 09:45 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 03:07 PM
