How Hard Is It To Change The Tub Diverter Location? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2013, 04:51 PM   #1
How hard is it to change the tub diverter location?
Evening.
I have an older style bath/shower control with the diverter located below, but not contained within, the control knob (it is a push/pull pin).
I want to update to a diverter that's located on the tip of the spout (so I can update/replace the entire hardware set).
I'm having a plumber come in to look at it (the tub wall is already exposed) but I want to have an idea of what to expect before he looks at it. I assume the older diverter will have to be removed, a new section put in its place, and then we can proceed with the update?
Hope this makes sense.
cne24 is offline   Reply With Quote
Old 05-20-2013, 07:24 PM   #2
Rewards Points: 34
Changing to a tub spout diverter is easy. The spout screws onto the pipe that comes from the shower valve. When you update the valve it may come with a matching tub spout.
Dan
djlandkpl is offline   Reply With Quote
Tags
diverter bathtub faucet , diverter tub spout , diverter valve
Hard wire or not to hard wire into switch heater GRed Electrical 18 02-08-2013 08:53 AM
Tub spout diverter operation question daluu Plumbing 7 02-06-2013 07:16 PM
Adding a Hard Start Kit rgarcia1801 HVAC 11 10-21-2012 05:31 PM
removing bathtub faucet diverter xconx Plumbing 6 10-10-2011 11:17 AM
Hard to change position/size of windows? zel General DIY Discussions 20 07-13-2007 07:30 AM
